Installing shower enclosure
s2airflow
Post by s2airflow »
Just a niggling thought- is it best to tile the shower area first & then instal the enclosure onto the tiles,or does the enclosure get built first and then tile up to that internally?What's the general thought on that.Its going onto Hardieboard backer.Thanks guys.
ayjay
Has thanked: 458 times
Been thanked: 1708 times
Re: Installing shower enclosure
Post by ayjay »
s2airflow wrote:- is it best to tile the shower area first & then install the enclosure onto the tiles
Yes; it probably tells you that in the instructions with the shower enclosure.
Has thanked: 820 times
Been thanked: 3521 times
Tile first is the right way. Make a note of where the screws are fixing the board up. It is a good idea to have a look at the fixing positions on the enclosure so you can make sure that there is clear passage through backer and frame to get a good fix.
Has thanked: 1414 times
Been thanked: 4019 times
My method would be instal shower tray, then tile, then the rest of the enclosure.
s2airflow
Post by s2airflow »
Thanks for the replies - there was no mention in the enclosure instructions so I'll begin the tiling first.Dave.
