Corner Worktop for hob
royaloakcarpentry
Has thanked: 39 times
Been thanked: 621 times
Re: Corner Worktop for hob
Post by royaloakcarpentry »
You don't need to use bolts for solid worktops. But you will have done them now.
Virgin
Post by Virgin »
:lol: royaloakcarpentry I've only done one half so far
With wrong cuts basically I done a cut for a profiled edge on a square edge ....  needs a little trim ...
WITH WRONG CUTS (1000x750).JPG (480.05 KiB) Viewed 1833 times
Close up in case you can't see the gap
WRONG CUTS CLOSE UP (1000x750).JPG (477.79 KiB) Viewed 1833 times
New cuts with right hand worktop .... (face up)
FACE UP RIGHT RUN (1000x750).JPG (480.42 KiB) Viewed 1833 times
Connecting bolt slots repositioned from standard jig position to avoid cutting into  cabinets to get access to the nut when assembling ...
DOG BONES (1000x750).JPG (470.28 KiB) Viewed 1833 times
Virgin
Post by Virgin »
I'm feeling more :oops: as the post goes on pics in the wrong order is the least of my worries :dunno:
Virgin
Post by Virgin »
royaloakcarpentry
What would you secure them together with then :binky:
moderator2
UHM Super Moderator
Has thanked: 155 times
Been thanked: 569 times
Post by moderator2 »
Virgin wrote:I'm feeling more :oops: as the post goes on pics in the wrong order is the least of my worries :dunno:
I have re-arranged them into (Hopefully) the right order. Mod 2
Virgin
Post by Virgin »
Cheers Mod 2 :thumbright:
Loosenup
Has thanked: 3 times
Been thanked: 8 times
Post by Loosenup »
In situations like this ( I know I am a bit late ) I usually make a template out of 5 mm mdf .. not as expensive as timber lol.
Once I get the template perfect , just lay the pieces on top and cut around em never failed yet on awkward cuts.
Phill
Virgin
Post by Virgin »
Loosenup
cheers I did consider using ply/mdf but it was the profile on the front edge that I couldn't get my head around ... I wrongly assumed that it would still match using a jig on square edged worktop ::b
In hindsight it was a large piece of wood :sad: and I could have had a play oversized before cutting to the size required ....
still trying to salvage the worktops which is possible but will never look right to a trained eye but will have to do :cussing: ( a term I hate to use) the mitres are about 20mm out either side of the corner hob worktop ...
almost there but disappointed with my result :error:
Locked
Return to “Kitchen Fitting”
