Tiling around the bath, not 90 degree big gap, help !?
Hello,
Please see the attached photos i have tiled the wall in my bathroom but the wall isnt straight and theres a big gap. This is just above the shower and needs to be properly sealed.
Anyone have any ideas, when it was plastered i should have got him to pull the wall out. is the only option to pull the tiles out and then fill with loads of grout. luckily a shower screen need to be fixed there so i could get away with it but lots of work. any ideas ?
thanks in advance
sorry for delay with pics, strict rules on this site !
thanks in advance
- IMG_2188a (4).JPG (13.99 KiB) Viewed 14829 times
- img_2186 (3).jpg (43.93 KiB) Viewed 14829 times
- BANNED
I don't suppose you can remove the bath, chisel away some of the plaster and then push the bath further in to the wall, or will this create a gap at the other end of the bath?
You can squeeze some tiles behind the bath, to fill the gap slightly then use some quadrant tiles like this-
There might be some better ideas when one of the tilers logs on
Last edited by ultimatehandyman on Tue Jul 25, 2006 8:05 pm, edited 1 time in total.
- BANNED
know it all !! Well the bath wont move back into the wall as the toilet waste is behind it adn its already a tight fit. i did notice it and told the tiler but he just tiled it. how about a slither of wood or something and then that ? but then i suppose the bath moves etc.
you know where i can get some quadrant tiles, made of travertine, possibly white?
- BANNED
mudster from at stone is your marble manwelsh wrote:know it all !! Well the bath wont move back into the wall as the toilet waste is behind it adn its already a tight fit. i did notice it and told the tiler but he just tiled it. how about a slither of wood or something and then that ? but then i suppose the bath moves etc.
- Tiling Expert
I was once faced with a situation like this with a stone shower tray that couldn't be removed, we needed to deal with a gap in an unsightly way, qudrant tiles are the obvious solution, but they aren't reliable and have joints, so we decided to use UPVC quadrant all the way around the tray to make it loo fitted by design.
I'd suggest tha'ts your best bet, but don't just fit is on the wall with the gap, fit it all the way around the bath if there's room, it' doesn't look like it was just used a problem solver.
If this is an acrylic bath it will flex with the bath in a way that ceramic or stone quad tiles can't.
