Tiling around the bath, not 90 degree big gap, help !?
welsh
Post by welsh »
Hello,
Please see the attached photos i have tiled the wall in my bathroom but the wall isnt straight and theres a big gap. This is just above the shower and needs to be properly sealed.
Anyone have any ideas, when it was plastered i should have got him to pull the wall out. is the only option to pull the tiles out and then fill with loads of grout. luckily a shower screen need to be fixed there so i could get away with it but lots of work. any ideas ?
thanks in advance
sorry for delay with pics, strict rules on this site !
IMG_2188a (4).JPG (13.99 KiB) Viewed 14828 times
img_2186 (3).jpg (43.93 KiB) Viewed 14828 times
tim'll fix it
BANNED
Post by tim'll fix it »
I cant see a picture :sad:
Site Admin
Has thanked: 1012 times
Been thanked: 918 times
Have you tiled all the way to the ceiling or is that your first row of tiles above the bath?
That gap is pretty big :o
welsh
Post by welsh »
Guess?!?! all the way to the top :-(
a friend did it for me
Site Admin
I don't suppose you can remove the bath, chisel away some of the plaster and then push the bath further in to the wall, or will this create a gap at the other end of the bath?
You can squeeze some tiles behind the bath, to fill the gap slightly then use some quadrant tiles like this-
There might be some better ideas when one of the tilers logs on :?
Last edited by ultimatehandyman on Tue Jul 25, 2006 8:05 pm, edited 1 time in total.
welsh
Post by welsh »
thanks for the tips, the bath cant move unfortunately.
the quadrant tiles may be an idea !!
tim'll fix it
BANNED
if it was mine I would have chiselled the wall out first, without being a know it all, didnt you see the gap when just the bath was in.
In fact I would let the bath into the wall, quadrants will look like an after thought. Get it right now. :grin:
welsh
Post by welsh »
know it all !! Well the bath wont move back into the wall as the toilet waste is behind it adn its already a tight fit. i did notice it and told the tiler but he just tiled it. how about a slither of wood or something and then that ? but then i suppose the bath moves etc.
you know where i can get some quadrant tiles, made of travertine, possibly white?
tim'll fix it
BANNED
welsh wrote:know it all !! Well the bath wont move back into the wall as the toilet waste is behind it adn its already a tight fit. i did notice it and told the tiler but he just tiled it. how about a slither of wood or something and then that ? but then i suppose the bath moves etc.
mudster from at stone is your marble man
Site Admin
Dead link removed by Admin
welsh
Post by welsh »
thank for that was trying to work out what @stone was !!
Mudster
Tiling Expert
Post by Mudster »
I was once faced with a situation like this with a stone shower tray that couldn't be removed, we needed to deal with a gap in an unsightly way, qudrant tiles are the obvious solution, but they aren't reliable and have joints, so we decided to use UPVC quadrant all the way around the tray to make it loo fitted by design.
I'd suggest tha'ts your best bet, but don't just fit is on the wall with the gap, fit it all the way around the bath if there's room, it' doesn't look like it was just used a problem solver.
If this is an acrylic bath it will flex with the bath in a way that ceramic or stone quad tiles can't.
welsh
Post by welsh »
cheers mudster sounds good, have you got a piccy of the finished article? Or even a website link to the UPVC plastic sutff you are talking about?
would be a great help
thanks
amarg
Has thanked: 12 times
Been thanked: 32 times
Post by amarg »
Take a look at quadrant profile on this page-
http://www.casupply.co.uk/acatalog/fasc ... trims.html
