new HDD installing os 'a cd/dvd device driver is missing'
gasspark
Has thanked: 4 times
Been thanked: 37 times
Post by gasspark »
Hi All
Have a Packard Bell ixtreme PC, the old HDD took the knock, so went to install new HDD on PC the disc boots to the Vista installation screen but when I click install shows "a required CD\DVD device driver is required", so i brouse as the option is there, but cant load drivers as it cant see my DVD anymore.
Have been through many forums and search engines, seems the problem in my case is the sata drivers, alas have looked in bios and cant see anyway of going from raid to anywere
have given basic information as know from giving advice to give a bit till am told what u need, then to give that.
Prays for help as have been on this for a few days.
regards
john
kellys_eye
Has thanked: 357 times
Been thanked: 1790 times
Re: new HDD installing os 'a cd/dvd device driver is missing
Post by kellys_eye »
Can you load the driver onto a USB stick and access it from there?
gasspark
Post by gasspark »
dont have one at the moment can I inbed the drivers in vista sources folder I brouse it that way
chat_to_rich
Been thanked: 45 times
Post by chat_to_rich »
It's possible to inject drivers into a Vista image http://www.windowspcguy.net/?p=29 and http://social.technet.microsoft.com/For ... 28c0597583, but it's quite involved. I think your best bet is to put the SATA drivers onto a USB stick.
If you're really desperate to get it going you could change the SATA mode to IDE, but this won't help if you need to use RAID.
BillyGoat
Troll Headbutter
Has thanked: 386 times
Been thanked: 796 times
Post by BillyGoat »
Which model of iXtreme is it?
Unless it's got two HDDs in (possible....with that range) then you don't need to be setup in RAID - AHCI or IDE (might be listed as compatability mode) should be fine in the BIOS and allow the media to work fine.
BG
Return to “Computers”
