Gas Leak Detector
- Has thanked: 83 times
- Been thanked: 24 times
Gas Leak Detector
Can anyone recomendagood gas leak detection kit/tool?
Men will always be kids. Even after they have grown up, they keep trying to go back where they originally came from!
- UHM Super Moderator
- Has thanked: 141 times
- Been thanked: 362 times
Re: Gas Leak Detector
- These users thanked the author moderator6 for the post:
- tombarry
Nice one Mod6.
I can just hear the whole place go BOOM. No, I'll pass on that one.
- Razor
- Has thanked: 483 times
- Been thanked: 1251 times
How much do you want to spend? My Anton would be around £700 to buy!
What's it for? If you're worried about a leak in your own place just ring National Grid on 0800 111999 and they will check it out for free
- moggridgeplumbing
- Has thanked: 4 times
- Been thanked: 37 times
- These users thanked the author moggridgeplumbing for the post:
- kintangoman
thanks moggridgeplumbing.
will acquire that from bes
- Has thanked: 736 times
- Been thanked: 2341 times
didnt know the happy mondays were branching outkintangoman wrote:thanks moggridgeplumbing.
http://bit.ly/IKbeAR
No big-all, the info you have provided says the happy Mondays are a band of some sort.
I don't want to play some music, so don't try and confuse me? I just want to spend around £150 for a gas leak detector (electronic or battery operated one, that is)! That's all.
- Has thanked: 18 times
- Been thanked: 13 times
Sorry seeing the swan matches reminded me
Ah yes my dad now in Rogues heaven,
Used a match -no it’s true, his mate told me years later after they returned from a liquid lunch
to finish off the kitchen supply, but forgot to turn the gas off -
lit the torch up- applied to solder joint - boom -huge flame,
my dad’s mate ran but the o'l man being a pro manage to turn gas off ,phew
Sorry again as it doesn’t help with detector
It's probably worth me pointing out that KTM is indeed a fully registered gas guy
- ayjay
- Has thanked: 458 times
- Been thanked: 1708 times
The box of matches made I laugh.
When I were a nipper and in the Brussel Sprouts, we had a gas fire at our HQ which leaked a bit from the supply pipe when the fire was turned on, the simple solution (to us) was to ignite the leak.
The leak used to burn with a small flame about the size of a pilot light but because it was burning it didn't smell as it did when unlit, it's terrifying now to think about it but it worked just fine for us.
I do admit the matches idea was a good joke. It did make me laugh, loads.
Tango
Tango
- These users thanked the author kintangoman for the post:
- moderator6
