Have an annoying flicker, loads of white lines on the right hand side of the screen, but it only does it with the one monitor.
If I boot with both monitors on line neither does it.
A-Z CONTENTS | DISCLAIMER | DIY VIDEO | HOME | SAFETY FIRST | FORUM RULES
When you change them over Scruff, have a look which outputs they use. ( I suspect one may use a different type of output to the other one)thescruff wrote:Both plug straight in to the same card at the back JoinerJohn.
It doesn't show on a print screen Billy, it was a my computer update not a windows update.
I'll swap the monitors over tomorrow if I get the chance.
