due to rip out the current bath and basin soon and was wondering the best way to tackle tiling afterwards
bathroom-update-early-days-t49034.html
has got a few shots of it after the father and I put a toilet in.
now i'm coming to remove the bath and basin, As you can see, the end of the bath doesn't meet the wall and has been tiled over.
Idea at minute is the following,
1) battern out the far wall the toilet and sink is on to take up the difference of the bath not fitting flush top and bottom,
2) hide the pipes in the false wall behind the battern
3) rip out the window cill which sticks out nearly 2 inch
4) plasterboard it
5) fit bath with a bit of play top and bottom for panel to fit (i.e. not get stuck on tiles
5) tile it.
The other walls i'll check to see how true they are, presuming its plaster straight to block / brickwork as its a 1950's house.
if they're true enough I was only planning on sanding the paint off and get back to plaster.
the wall with pen marks shows roughly where the shower will go above the new bath,
this wall will be chased out for shower pipes.
Not sure whether to have all the walls tiled or just ceiling to bath, splash back behind sink and tiled window cill.
Any glaring problems tiling wise from what i'm looking at or hints to start me off?
Have read to use at least 12.5mm plasterboard as a backer, only planning on small ceramics (20 / 30 cm ish?)
Should I tank every wall or just the ones round the bath?
