Be aware that the mitre saw max cut width is 120mm, some laminates are wider than this.
I tend to use a jigsaw for laminate these days. Laminate will knacker blades pretty quickly.
Evolution metal cutting saw bargain
- Has thanked: 736 times
- Been thanked: 2341 times
Re: Evolution metal cutting saw bargain
i have always used a jigsaw on laminate usually over my knee at floor level but dont tell anyone
- Has thanked: 32 times
- Been thanked: 807 times
i use my chop saw lol. wayy quicker. obv apart from rips.
btw we have an evolution vibrating whacker thing. petrol engine and all that. used it loads and its ok though a touch light for anything other than small driveways etc
big-all wrote:i have always used a jigsaw on laminate usually over my knee at floor level but dont tell anyone
I always use a jigsaw for laminate as it seems to do the best job with less dust than a circular or chop saw. I used a chop saw once and it would often spark when cutting some laminates!
A few years ago I bought a full pallet of glue together laminate for £100 (slight seconds) I managed to do 9 large rooms and 3 landings with it and still had loads left, I cut almost every plank using my cordless Dewalt which is brilliant as the battery lasts ages when cutting laminate.
- Rich-Ando
- Pro Tradesman
- Has thanked: 135 times
- Been thanked: 304 times
i do as Fin does, i always use my chop saw. Jig saws are fine if you arn't bothered about a 100% straight edge. they also take far too long. a chop saw cuts straight through laminate in 1-2 seconds, although mine is the one with a 12" blade in it. as above, the only downfall is that it does blunten the blade so i have two blades, one for fine wood and the other for laminate.
dust wise, i have an extract bag on mine so it get about the same as a jig saw externally.
