Fitting kitchen door.
Hampstead
Post by Hampstead »
Hi, I have fitted an integrated washing machine in my kitchen and I'm trying to work out how to fit the door.
The washing machine has captive nuts to fit the hinge to, but I have no idea how to fit them to the door. The normal rebate is not there. The doors are dead flat.
I'm guessing I'll have to use a router. Are there special bits for this?
If anybody knows of a video tutorial, I'd really appreciate it.
Site Admin
Has thanked: 1012 times
Been thanked: 918 times
Hi, and welcome :hello2:
I have never fitted an integral machine before but I know how you make the holes for using concealed hinges. Take a look here- http://www.ultimatehandyman.co.uk/diy/d ... itting.htm
You will see that I have used a pillar drill and a hinge cutter bit, there is 2 sizes of these 35mm and 26mm so make sure you get the right one-
http://www.screwfix.com/app/sfd/cat/pro ... 6&ts=58951
http://www.screwfix.com/app/sfd/cat/pro ... 9&ts=58991
By using a pillar drill you can use the depth stop to make 100% certain that you will not come out the other side of the door.
Hope this helps a little.
owen
BANNED
Post by owen »
normally integrated appliance doors fit using special concealed hinges, which you need to drill the door for exactly as UHM describes above.
what you need to be careful of is that the holes need to be in the right place, as there is not usually much adjustment on the hinges.
your washing machine should have come with a template or instructions showing exactly where the hinge holes need to be drilled.
Hampstead
Post by Hampstead »
Ah ha - that looks like what I need. Will they fit in a router?
Site Admin
Hampstead wrote:Ah ha - that looks like what I need. Will they fit in a router?
I think they will fit in a router, if I remember rightly the shaft on both size cutters is the same size.
Hampstead
Post by Hampstead »
wish me luck - I'm a terrible DIYer, but I can't get anybody to come out and do the job!
Has thanked: 823 times
Been thanked: 3560 times
Use a cordless drill and blip the trigger. Punch a centre point which will help you align the cutter correctly. You will have more control with the cutter in a cordless and less chance of going through the door.
carhartt kid
Has thanked: 3 times
Post by carhartt kid »
The pro's use a forstner bit. Available from screwfick's for about £5-10??? I use the budget set and resharpen them when needs be. Just measure up and mark a centre point with a bradawl. Then whack the right size one of these in a battery drill and cut away. Stop before you go to deep and drop the hinge in a few times to check it sits flush!!!
http://www.screwfix.com/search.do;jsess ... h=forstner
http://www.carhartt.com/
dirtydeeds
Craftsman Carpenter
Post by dirtydeeds »
try fitting the ...........................................
im looking for an pc acceptble word here
try fitting the bstads when its a repair and there aint no instructions
the customer has called you in because he, his wife, the "boy" the entire family, his mates and "three tradesman" have all had a go at it
then he tells you.................. its only a small door
finding a pc word for that guy.......................
it isnt possible
