Water damage to patio tiles.
- Has thanked: 10 times
Leaking tap caused this damage over a few months.
Tried a product called Agua Fuerte which is a mild acid cleaner but no luck.
Any ideas apart from re-tiling?
Re: Water damage to patio tiles.
Have you tried a pressure washer?
If you got a really high pressure model I think it would blast most of that off.
Tried that along with an acid cleaner.
I think it's limescale, ingrained from a dripping tap over an 8 month period.
I've uploaded some more photos.
Is there a really strong limescale cleaner on the market?
Everbuild make a couple of products that might work
CEMSTRIP
407 MORTAR STAIN REMOVER
One of those might do it.
CEMSTRIP
- These users thanked the author ultimatehandyman for the post:
- arambol
I think sand blasting will be too rough and will scratch the surface badly.
- DTWCeramics
- Has thanked: 13 times
- Been thanked: 43 times
Were the terracotta tiles sealed at all? Looks as if they were put down and not sealed.
Lithofin do a good range of products that are made for rescueing(sp?) tiles, you may want to give them a call on 01962 732 126 - they offer full free technical advice.
You may want to e-mail them these pictures as well, as they may be able to help :)
Hope it's helped.
Matt.
Hope it's helped.
Matt.
