Finding old tiles
roggrandad
Has thanked: 18 times
Finding old tiles
Post by roggrandad »
Hi
We have moved in to a new bungalow a short while ago and would like to change the toilet cistern and the basin but the cistern and basin were fitted before the tiles,I don't know where the tiles came from or how old they are can someone please give me any information on tracking down some replacement tiles.
They are 30cmx20cm wall tiles I have taken a picture of them and will try and post.
Thank you.
Roger.
tiles 005+4.jpg (195.5 KiB) Viewed 1537 times
DTWCeramics
Has thanked: 13 times
Been thanked: 43 times
Re: Finding old tiles
Post by DTWCeramics »
Hi Rog,
bit hard to see from your picture, but seems to be a generic 20x30 wall tile.
A lot of diy stores will carry these, I know a lot of online stores do as well.
You're more than likely not going to be able to match the existing tiles due to shading (Different colours between batches)
Hope this has helped,
Matt :thumbleft:
Colour Republic
Has thanked: 263 times
Been thanked: 544 times
Post by Colour Republic »
Try searching for 'tiles in your garage' but before you do that check that spares weren't left under the bath ;)
roggrandad
Hi Matt
Thank you for reply,I will have to do a lot of looking around then,I think I could get away with the different shade as they will be mainly behind the basin and cistern.
Again thanks.
Roger.
roggrandad
Hi
I have looked in the garage and I looked under the bath but no joy.
Thanks.
DTWCeramics
roggrandad wrote:Hi Matt
Again thanks.
Roger.
No Problem Roger :)
As stated above tiles in my garage might be an idea if you can't find any, but I doubt you'll struggle.
If you have a loose piece take it into the shop with you, makes it a ton easier for us.
Cheers,
Matt :thumbleft:
Colour Republic
roggrandad wrote:Hi
Thanks.
Sorry I meant searching goggle for 'tiles in your garage', it's a website ;)
roggrandad
Hi
That's a good idea I will have the bath panel off again and see if there are any long pieces below the bath and I might be able to take a piece off.
Thanks.
DTWCeramics
Good luck Roger :)
http://www.tilesinyourgarage.com/ - that's the site Colour Republic mentioned :)
Hope it helps
Matt :thumbleft:
