Supplier for 616wide worktop - 4m length
Locked
cascas
Post by cascas »
Howdens do not supply worktops longer than 3m.
Does anywhere know where I can get a 616wide worktop in a 4m length (38mm laminate / black matte), otherwise it looks like the units need cutting down!!
Has thanked: 736 times
Been thanked: 2341 times
Re: Supplier for 616wide worktop - 4m length
4 metres is not much cheaper than 2x3m could you work with 2 lengths :dunno:
speed
Has thanked: 35 times
Been thanked: 257 times
Post by speed »
id rather cut 5mm off the service void than have a straight join.
are the units ready fitted or is it a new fit? ive fitted 600mm b&poo worktops to howdens units in the past with no problems, i ended up with around 8mm overhang
cascas
Post by cascas »
Units are new and I have just fitted (didnt realise at the time that 616 width was rare). Rather no cut off from the void if I can help it, as I have a 931 corner unit that is tight (no void) as it is.
I have looked at my own kitchen (fitted by a well know local company) and found that the units are also 575, with a 600 worktop - and it looks ok, so tempted by sticking to a 600.
Loosenup
Has thanked: 3 times
Been thanked: 8 times
Post by Loosenup »
buy a 665 double post formed and cut it to size , most worktops suppliers can do this size in 4.1
Locked
Return to “Kitchen Fitting”
