Attaching a Stainless Steel Splashback
Locked
Topjacket
Has thanked: 13 times
Post by Topjacket »
Hi All
Sorry if this isn't in the correct section, I wasn't sure if I should put it here in the metal forum.
I have had some large stainless steel sheet cut to fit inside an old chimmney breast in my kitchen. It is going to have a range cooker infront of it.
I was wondering if there is a good product to use to attached the stainless steel to a newly plastered wall. I'm not sure if I need to get something that will deal with the heat from the oven.
Thanks in advance for any advice.
Cheers
Jim
BRUNO
Has thanked: 34 times
Been thanked: 67 times
Re: Attaching a Stainless Steel Splashback
Post by BRUNO »
I did this for my brother, I used mirror screws( and plugs) with the silver dome heads, and put a zig zag bead of sticks all adhesive on the back for good measure, and a very thin bead of silcone around the edges. 3 years later and no problems. It was about 1m x .8m.
With hindsight you might want todo it without the mirror screws, the don't look too bad, just might stick out a bit in a contemporary kitchen
speed
Has thanked: 35 times
Been thanked: 257 times
Post by speed »
i had to remove one a few weeks ago to fit an extractor in the chimney, it was stuck on with a few blobs of clear silicone and it was well stuck, so id say silicone.
you will need a few panel pins for the sheet to rest on until it sets
Topjacket
Post by Topjacket »
Thank you both very much for your replies.
Cheers
Jim
fin
Has thanked: 32 times
Been thanked: 807 times
Post by fin »
clear sillicone for me. its a bugger to get that stuff off when its set.
Locked
Return to “Kitchen Fitting”
