mason mitres
- Has thanked: 32 times
- Been thanked: 807 times
mason mitres
just wondering what you lot use when you do masons mitres? i stopped using that colourfill stuff. it goes of like the crack of a gun i find. so not enough time for adjustments. the last few kitchens ive done ive just used clear silicone.
- Has thanked: 35 times
- Been thanked: 257 times
Re: mason mitres
i use colourfill or d4grade pva, as its totaly waterproof
http://www.toolstation.com/shop/Adhesiv ... 198/p61864
- Has thanked: 736 times
- Been thanked: 2341 times
Re: mason mitres
thats the stuff i use all the timespeed wrote:i use colourfill or d4grade pva, as its totaly waterproof
or the pvu 5 mins foaming glue
http://www.toolstation.com/shop/Adhesiv ... 198/p93568
but not for worktops i hasten to add
colourfill is fine if you do a dry run
- joinerjohn
- Has thanked: 17 times
- Been thanked: 315 times
Re: mason mitres
As Big-all says, colorfill is fine , as long as you do a dry run, but your right, it does go off bloody fast. I have used clear silicon before (and black on very dark worktops)
Re: mason mitres
aye i make sure there gonna go together first anyway. just found clear (or black on dark tops) works pretty well. pity the colourfill stuff doesnt go off a bit slower.
- Job and Knock
- Old School Chippie
- Has thanked: 742 times
- Been thanked: 1573 times
Re: mason mitres
I'm with you there. I only use Colorfill if it's a wierd shade and I can't get away with using silicone (which comes in a range of exciting colours these days)joinerjohn wrote:As Big-all says, colorfill is fine , as long as you do a dry run, but your right, it does go off bloody fast. I have used clear silicon before (and black on very dark worktops)
