Kitchen first or laminate floor??
- Has thanked: 4 times
Hi All,
i'm fitting a kitchen at the weekend but i also have some laminate flooring to fit. At the moment it is an empty shell.
Do i fit all the floor units first, then lay the floor up to and under the plinth, or do i lay the floor first then fit the kitchen on top?
I'm guessing the weight of the units will stop the allowance of expansion.
Cheers
Darren
Cheers
Darren
- Has thanked: 23 times
- Been thanked: 16 times
Re: Kitchen first or laminate floor??
If I were doing it I would fit the laminate after. It may be easier to fit it before the units go in, however I would think the kitchen will outlast the laminate so it could be a nightmare when you come to change it. You will also save a few ££ on not fitting it under the units.
Just my 2 penneth.
Just my 2 penneth.
- These users thanked the author silver_star for the post:
- xxwispxx
- joinerjohn
- Has thanked: 17 times
- Been thanked: 315 times
I've never rated laminate flooring in a kitchen. The potential for getting it wet is always there.
![Wink :wink:](./images/smilies/icon_wink.gif)
- These users thanked the author joinerjohn for the post:
- xxwispxx
- kellys_eye
- Has thanked: 357 times
- Been thanked: 1790 times
Whatever you use I'd go wall-to-wall as, if you ever consider changing the layout, you'll inevitably end up with having to recover the whole floor to hide 'holes'.
- xxwispxx
- Has thanked: 736 times
- Been thanked: 2342 times
several considerations most already mentioned
if you lay the floor first then you may have expansion problems but are relying on the floor outlasting the units
if you lay the units first you need to allow for the fact your floor will reduce the clearance under worktops by around 12mm
- Has thanked: 11 times
Laminate flooring is cheap, I would install it wall to wall first. It is only when I use a fancy floor finish like granite that I do not install it wall to wall but still lay it first to leave some of it under the units.
Also, like other people said, I am suspicious of laminate flooring in bathrooms and kitchens unless somebody sells one that has a warranty against damage by water.
