Critical updates
- BANNED
- Has thanked: 9 times
- Been thanked: 4 times
Re: Critical updates
I would also check your 'System Event' reports in Admin Tools which should store what happened at time of crash.
Also here is a handy hint, if like me some spurious software has prevented you from running automatic updates as it is 'missing':
http://support.microsoft.com/kb/883614
Once you have visited this page, bookmark it - it took me ages to find it and it had been a long time since I last used it to resolve a similar problem years ago! (That said, XP is due for retirement in 2 years time!)
- thescruff
- Has thanked: 360 times
- Been thanked: 3735 times
Runs for about an hour then crashes with the error.
Technical information reads.
Stop: 0x000000F4 (0x0000000000000003, 0xFFFFFA800B14A740, 0xFFFFFA800B14AA20, 0xFFFFF800003398510)
Collecting data for crash dump
Initialzing disk for crash dump
Physical memory dump failed with status 0xc0000010.
- BANNED
I posted your error codes in to DuckDuckGo search engine and found this interesting article:
http://www.hardwareanalysis.com/content/topic/78076/
- thescruff
- BANNED
- thescruff
Blimey I just looked at that site and registered.
Got a feeling it's tooooooooo technical for me.
- thescruff
The computer freezes first then a few minutes later I get the blue screen with the below on it.
A problem has been detected and windows has been shut down to protect your computer.
A process or thread crucial to system operation has unexpectedly exited or been terminated.
If this is the first time you’ve seen this error screen, restart your computer, if this screen appears again follow these steps.
Check to make sure any new hardware or software is properly installed.
If this is a new installation ask your hardware or software manufacturer for any windows updates you may need.
If problem continues, disable or remove any newly installed hardware or software. Disable BIOS memory options such as catching or shadowing.
If you need to use safe mode to remove or disable components, restart your computer press f8, To select advanced start-up options and then safe mode.
Technical information.
Stop: 0x000000F4 (0x0000000000000003, 0xFFFFFA800B14A740, 0xFFFFFA800B14AA20, 0xFFFFF80003398510)
Collecting data for crash dump…
Initializing disk for crash dump…
- Has thanked: 31 times
- Been thanked: 40 times
I'm guessing you have a faulty memory DIMM, and the error codes suggest that as a possibility. Download Memtest of your preference for optical disc or USB memory stick: http://www.memtest.org/#downiso
- burn a CD or DVD, or copy to memory stick
- reboot (check your BIOS settings if you need to change the boot drive order)
- allow Memtest to run 5-6 passes of testing
- if the tests complete without errors then reboot and pull the disc/USB stick, you know the memory isn't faulty*
- if you see errors shut down the PC, open it up and remove the defective memory DIMM(s)
- reboot and test again...
- repeat until you have tested all DIMMs and DIMM sockets
- thescruff
Ran memtest and no errors.
I did a sevens forum zip (SF Diagnostic tool) if it helps, it certainly makes interesting reading if you know what it says. Zip 3 was the latest.
- thescruff-zip3.zip
- (1.58 MiB) Downloaded 166 times
- chat_to_rich
- Been thanked: 45 times
Blue screens are often caused by faulty drivers, or hardware problems. I don't think Adobe is the cause of the problem.
The answer to the problem may lie in the crash dump. I've got basic instructions on how to analyse amemory dumps here http://richardstk.wordpress.com/2010/11 ... -of-death/ If you can upload the dump somewhere I could take a look at it for you. If you choose to uploaded it for me to take a look, zip it first.
- thescruff
- chat_to_rich
Hi scruff
Am I right in thinking you bought the PC discussed here deleted-t45462-60.html? If you did can you check to see if the SSD is the OCZ Solid 3. The controller on that drive had a few firmware issues when it was first released and unless you've updated the firmware on the SSD it will probably be very out of date. One of the issues with the early firmware was the STOP 0x000000F4 error you've had.
You can download a tool to update the SSD firmware here http://www.ocztechnology.com/ssd_tools/SandForce_Based/. You can't update the firmware on the drive if it's running Windows, so you have to use the Linux tool. I've run this tool on my own SSDs from a USB flash drive without problem, but it's best to backup any critical data.
It may not cure the problem, but it's worth a try.
- thescruff
It's a Crucial
DBNEPG 3005
M4 SSD 2.5
128 SATA 6Gb/s
Firmware rev 0002
S/N 1123031167 CE
ww N: 500A0751031167 CE
Memory is Mushkin Blackline 996988
2 x 4Gb) 8Gb.
pc3L128009-9-9-24-1 35v.
Thank for any assistance.
I'll boot it up in a while and run that last program.
Yes it is the computer in the link.
I remember when they built it they had stability problems but didn't say what.
DBNEPG 3005
M4 SSD 2.5
128 SATA 6Gb/s
Firmware rev 0002
S/N 1123031167 CE
2 x 4Gb) 8Gb.
- chat_to_rich
The Crucial M4 uses a different controller to the Solid 3. The latest firmware for this drive is 0009, you're on 0002. You can get the firmware here http://www.crucial.com/support/firmware.aspx I'm not aware of STOP errors with this controller, but give the update a try.
- thescruff
Is the Is the SF Diagnostic zip any good to you Rich.
- thescruff-zip5.zip
- (1.71 MiB) Downloaded 157 times
