I want to lay 10cm x 10cm floor tiles on wet room shower tray but I'm not sure whether to use a 10mm or a 6mm notch trowel.
Any advice appreciated
Which trowel?
- Has thanked: 1414 times
- Been thanked: 4019 times
Re: Which trowel?
Check your tile sizes ??
Re: Which trowel?
10 mm trowel, you need a full bed of addy.
- DTWCeramics
- Has thanked: 13 times
- Been thanked: 43 times
Re: Which trowel?
if it's only a 100mmx100mm tile, anything from 6mm up will suffice. I'd personally go with either an 8mm or a 10mm for these.
Cheers
Cheers
Matt
