Kitchen Worktop Help!
Scout
Has thanked: 2 times
Post by Scout »
Hi, I'm redoing my kitchen and could do with some advice as to where I can or can't put a worktop joint!
The kitchen is just under 4m in length and in that stretch I have to fit a hob, sink and 3 undercounter appliances.
I am guessing that the join will have to be in one of the small spaces left and not over the appliances?
Any advice gratefully accepted!!
Has thanked: 1415 times
Been thanked: 4024 times
Re: Kitchen Worktop Help!
If you haven't already bought the work tops, you can buy a longer length and cut to size....an example (I've not used this site btw)
http://www.kitchendoorworkshop.co.uk/pr ... ktops.html
Inky Pete
Has thanked: 12 times
Been thanked: 161 times
Post by Inky Pete »
:withstupid:
Beaten to it!
Inky Pete wrote::withstupid:
Beaten to it!
The Mrs. always says I'm quick....I think that's a good thing ??? :hiding:
Scout
Post by Scout »
Being on a tight budget the extra cost is a bit difficult to justify compared to an off the shelf DIY store jobby!
I need a narrow 2m stretch for the other side of my kitchen too so I am gong to have to get 2 bits whatever.
I'll look further into longer worktops but would like to be able to compare all the options.
Has thanked: 736 times
Been thanked: 2342 times
Scout wrote:Being on a tight budget the extra cost is a bit difficult to justify compared to an off the shelf DIY store jobby!
by this statement you will have 2 options 1m then 3m or 3m then 1m :dunno:
so choose the option that is farthest away from the sink as long as its over a cabinet and hopefully away from the main work area
Scout
Scout
Post by Scout »
I'll keep fiddling with my little cut out bits of paper till I find a layout that works!
Inky Pete
Post by Inky Pete »
Maybe buy two lengths at 3.6m (B&Q do them that size at not much more than the 3m ones) if you need more options.
Kitchens4DIY
Post by Kitchens4DIY »
Some worktop makers provide longer lengths. Duropal for example provide worktops in 4.1m lengths.
MrBrennan
Post by MrBrennan »
If you are still stuck with your worktop dilemma then I have a friend who can help you out. He runs a worktop supplying and fitting company and I'm sure he'd be happy to answer your questions.
LINK REMOVED! then tell him to come here and help people, please do not post advertising links to people businesses on here - Rich Ando
Hope you work it out mate, have a really great new year!
Mr B
royaloakcarpentry
Has thanked: 39 times
Been thanked: 621 times
Post by royaloakcarpentry »
Even lower quality budget granite is going to be out of his price range.
not sure if he would want to stoop as low as to use spam though.
Gadget
Jack Of All Trades
Has thanked: 344 times
Been thanked: 342 times
Post by Gadget »
Not even to make a sandwich?.. :wink:
By eck! ©
royaloakcarpentry
he hasn't got worktops to make the sandwiches on yet
Rich-Ando
Pro Tradesman
Has thanked: 135 times
Been thanked: 304 times
Post by Rich-Ando »
i would have said that by the time you buy the additional length and then pay somebody to do the proper clamped joint you will spend more than buying one longer 4M length.
unless you were thinking of using one of those horrible jointing metal strips. don't do that because you will regret it, they look dam awful.
if you meant you are putting two pieces in an "L" shape then as above, buy a 3.6M length for the 4M wall as you will have to cut about 150mm off it anyway for a corner join. then join another length to that for the L side.
it might be easier to post a picture of what you have and what you need, we can see then.
moderator2
UHM Super Moderator
Has thanked: 155 times
Been thanked: 570 times
Post by moderator2 »
MrBrennan. 99.9% of people who post a link like that in their first post turn out to be spammers. It may be that you are the exception.
However, if you read the rules you will see that foul or abusive language is not tolerated on this forum.
Consider this a final warning.
Happy New Year.
EDIT. Whilst I was posting, MrBrennan, Wisely, deleted his post.
The warning still stands.
Locked
Return to “Kitchen Fitting”
