Any tips on how to remove grout haze.
Tiles have been grouted using Mapei Ultracolor Plus grout and has left a dusty/chalk film on the floor and wall tiles.
Anyone tried these products?
http://www.toppstiles.co.uk/tprod133/se ... -1ltr.html
Grout haze remover
- Has thanked: 1414 times
- Been thanked: 4019 times
Re: Grout haze remover
Clean water, a clean sponge and rag should be all you need, unless the tiles in question are porous, in which case they should have been sealed before laying..
- DTWCeramics
- Has thanked: 13 times
- Been thanked: 43 times
Hi Scolet,
If what Wino has said doesn't work,
Lithofin Cement Residue Remover - Cleans grout off without the slightest bit of hassle.
Cheers,
Matt
Cheers,
Matt
- These users thanked the author DTWCeramics for the post:
- scoletti
Matt
- Has thanked: 2 times
- Been thanked: 28 times
As wino said, grout haze should be no problem to get off unless the tiles needed to be sealed before they were grouted. Hopefully they havent sealed the grout haze in. What colour grout was used and what colour are the tiles?
- These users thanked the author haveagohero for the post:
- scoletti
- Has thanked: 27 times
- Been thanked: 2 times
The tiles don't need to be sealed.haveagohero wrote:As wino said, grout haze should be no problem to get off unless the tiles needed to be sealed before they were grouted. Hopefully they havent sealed the grout haze in. What colour grout was used and what colour are the tiles?
The colour is grey (Mapei 110 Uktracolour plus). Colour of tiles are cream/beige msrble effect.
All tiling is done so I'm going to clean it today using Wino's method, and see how I get on.
