Bedroom Project
Bedroom Project
Recently moved into our new house and have been slowly progressing room by room as it was not exactly to our taste.
Starting with the bedroom and will be hopefully putting up similar threads for the rest of the house.
Here goes......
The day after we moved in
Horrible up and over wardrobes that covered a lot of the window
One more before the strip out
Room stripped
Next up....relocate TV socket, recessed shower power cable and board and skim ceiling and plaster walls.
Old socket and aerial
New socket and aerial
Chase out for electrical cable & conduit
Filled conduit & scored ready for plastering
Ceiling set out and boarded
Skimmed
Wash coat
Shopping to get furniture & accessories
Painting finished, TV trial fit, Light, mirror, Floor & Skirting down, Shelves and Wall Art
Finished product
Hope that gives some inspiration.
Other bigger and better projects to follow.
A perfect example of why adding pics to the forum as an attachment, as opposed to using remote hosting makes sense.
The above post now becomes meaningless because the OP has either deleted or moved the images on the hosting site. Mod 2
I have removed the dead links to photobucket.
Here goes......
Room stripped
Skimmed
Wash coat
Finished product
- nick200
- Has thanked: 409 times
- Been thanked: 222 times
Re: Bedroom Project
Looks loads better and thanks for taking the time to post.
Nick
- Has thanked: 7 times
- Been thanked: 8 times
- Has thanked: 247 times
- Been thanked: 314 times
Re: Bedroom Project
Much nicer.
Flooring looks very nice
I should have taken some photos of this place.....when we moved in technotronic carpets, acid green walls in the living room (I had to wear sunglasses to look at it....made me queasy),Wallpaper with trippy patterns in 20 different shades in the bedroom and bright pink foam wallpaper in the bathroom....
Next place I will try and remember....likely will be a beige extravaganza given its flavour of the decade....yuck
Gone M.I.A.
- Has thanked: 13 times
- Been thanked: 74 times
Re: Bedroom Project
photo's have disappeared for me, photobucket strikes again
- These users thanked the author warmadmax for the post:
- moderator2
- moderator2
- UHM Super Moderator
- Has thanked: 155 times
- Been thanked: 566 times
Re: Bedroom Project
post them to a new reply following this : how-to-post-pictures-t254.html
i'm sure a mod wouldn't mind altering your original post once attached
