MIRA 415 COLD water even after replacing cartridge?
plumbing, drainage and waste water questions here please
Sar786
Post by Sar786 »
Hi Guys,
After alot of frustration I have no choice but to turn to you and ask a question.
I have a white MIRA 415 (Black Cartridge) shower which is approx 15 years old. It started off with going cold from hot and when you turn it off and on again it would be nice and hot but then go cold again.
Then after a few days it started to leak from the head.
So upon investigating I found ordered and changed the cartridge.
Now when I turn it on it gives me slightly warm and cold but no HOT.
I wanted to know the following:
1) is my showere completely bust?
2) Will I need to get a plumber out?
3) Is it easy to fit a like to like Mira shower?
Sar
January 2013
Site Admin
Has thanked: 1012 times
Been thanked: 918 times
Re: MIRA 415 COLD water even after replacing cartridge?
I'll move this to plumbing :wink:
I replaced one of these a few years back and had to adjust it-
Have a look at page 30 in the attached PDF.
mira-combiforce-415.pdf
(1.52 MiB) Downloaded 2906 times
thescruff
Has thanked: 360 times
Been thanked: 3735 times
Post by thescruff »
More details about the model No, and make/model of the boiller please.
You can adjust the temperature see the MIs admin posted.
How is the hot at other outlets.
Return to “Plumbing Forum”
