composite worktops burn mark
- Has thanked: 32 times
- Been thanked: 807 times
friend of mines parents have composite work tops. theres a small burn mark on one of em. anyone advise how to deal with it? apparently my mates dad has tried all kinds of things he can think of but no luck. (ive not seen this im just going off what ive been told)
ive only ever fitted standard chip board laminate work tops. and once did a kitchen with granite tops so my knowledge on this type is limited. to say the least
i recomended he called a local company that we got the granite tops from to see if they could advise. however they were shut today.
cheers lads.
cheers lads.
- Colour Republic
- Has thanked: 263 times
- Been thanked: 544 times
Re: composite worktops burn mark
It can be repaired that is the beauty of them. If it is shallow it can be sanded out, if its deep it can be cut out and filled. How noticeable that repair is will depend on the make and colour of the worktops
ive passed on a number for a joiner i know. hes experience in these sorta work tops so the lass at howdens says.
ill let yas know how it goes. be good if i can come by when he sorts the job out.
ok i called by this house tonight with my mate and had a quick look. its not a burn mark as i expected it to be.
what do you guys think?
(ps why is photobucket being a pain lately? what do you lot use to host pictures to put on here?)
Don't use remote hosting, Fin, attach the pic to the thread as I've done for you.
How to http://www.ultimatehandyman.co.uk/attachment.htm
i wasnt too impressed by the kitchen to be honest. the doors arent lined up as they really should have been for the price. and apparently soft closers were suposed to be fitted but never were. that was why i was there tonight as i ordered them so called by and fitted em. even the little covers on the hinges wernt put on.
heres one join on the work tops. the other 2 look neat
Photobucket image/link removed. pic attached. Mod 2.
- fin2.jpg (129.17 KiB) Viewed 2428 times
- Has thanked: 4 times
- Been thanked: 49 times
Looks to me like the fitter didn't clean his pencil lines off the Worktops before fitting them, or the glue supplied wasn't the correct one for the tops! Either way it won't be easy to get that out.
Are they a true solid surface or something like Mia or smart stone?
IF IT WERE EASY ITD B BORING!
