Camper van
Hitch
Has thanked: 77 times
Been thanked: 335 times
Camper van
Post by Hitch »
Been asked to fit out a camper van, some overhead cabinets, storage spaces/bench seats, shelving unit etc.
Im at a bit of a loss what to use. Thinking about 9mm/12mm mdf, painted, but hed prefer wood. Hes thinking about using just 'pine' (wickes softwood :lol:) I was thinking perhaps that in something like that it may not be as stable as perhaps it should be?
I want something that can rout, cut shape readily, without having to trim/bead many edges.
Any thoughts?
Wood Magnet
Been thanked: 3 times
Post by Wood Magnet »
The only time i've fitted a van out was with
ply, but thats what he wanted. What about
t&g that would rout or jigsaw easily. :scratch:
People forget how fast you did a job - but they remember how well you did it.
I no longer skinny dip, i chunky dunk these day's.
Tryanything
Been thanked: 4 times
Post by Tryanything »
Hi Hitch
Why not try veneered MDF and iron on edging
Has thanked: 736 times
Been thanked: 2341 times
in general weight is an issue they tend to use 4mm ply but you should opt for 6 or9 with 12 for horizontal surfaces
if its a seated area you should consider 12mm for side pannels and 18mm for horizontal then you wont need a frame for support
fixing to the bodywork can be a pain is it lined or ribbed[stantions] bodywork!!!!!
try and plan for things to have 2 or more uses like table for example fits between benches to make a sleeping area
doors should be sliding or not protrude to far when open
finger holes or very small round knobs are preferable
solid bolts or latches are preferable to hold doors shut
need any more ideas just shout :thumbright:
Hitch
Post by Hitch »
Well, we are going for a paint finish MDF to keep it simple.
Perfect Bigall, thats what i told him to get, 6 and 12mm mdf :thumbright:
Hitch
Post by Hitch »
Some 4mm ply too going in.
Seems he wants to bodge new frontages on, and not bother altering any frameworks :scratch:
just be carefull and try and source your materials from other than a caravan /camper suppler/spares shop as they are up to 3 times the price :scratch:
Hitch
Post by Hitch »
Timber etc from Wickes, theres only a few proper campy type bits to replace, hes already got them now.
:thumbright:
also remember if you replace a pannel with a thicher spec check for clearence as clearences are often very tight
as in replace a 6mm door panel with 9mm the door won't fully open because the adjoining door is only 7mm away :wink: :scratch:
Site Admin
Has thanked: 1012 times
Been thanked: 918 times
Where is Knoba when you need him :?
He did some good work on a camper van.
Mr Mike
Post by Mr Mike »
I must admit I would've gone for ply.
If you're going to use MDF, try and get Moisture Resistant, not only will it be more practical....but routs and cuts more cleanly..... :thumbright:
Hitch
Post by Hitch »
Cheap job is what he wants. Would have been nice to rip it all out and start afresh. Instead hes keeping some of the frames for benches/beds and just putting on a new fronts. Same in the kitchen area, just new fronts and doors built around the botched framework. :roll:
