Porcelain Tiles - Bosch GTR 30CE
- Has thanked: 11 times
I'm considering buying a Bosch GTR 30CE Pro Tiler kit and, as this is a "dry" system, was wondering how long the cores actually last. I could buy some cheap bits, drill a few holes, and then replace them, but I also need a router bit for profiling tiles.
Is the Bosch GTR a good investment or could I do the same job far more cost effectively ?
Thanks in advance for any advice.
- Has thanked: 104 times
- Been thanked: 490 times
Re: Porcelain Tiles - Bosch GTR 30CE
Not sure but I reckon that cheap bits won't last on porcelain - it's such a hard material and usually has to be water cooled
- These users thanked the author darrenba for the post:
- Technojunkie
Not seen that before but just watched a video on youtube.
It looks like they have adapted a rotozip to be able to hold diamond coated hole saws like they sell at Richon- richon-tools-t20002.html
After watching the video with the diamond milling tool it looked very hard work, I’d love to see that work on hard porcelain. The guy in the video looks like he is struggling with it !
It’s not something I’d ever consider buying but I can’t wait to hear some real reviews on it ;-)
I once tried a Rotozip, it was useless on hard tiles and the only thing it could cut was plasterboard. I sold it on ebay
- These users thanked the author ultimatehandyman for the post:
- Technojunkie
- Has thanked: 39 times
- Been thanked: 621 times
We use a few commercial tilers and the fact that none of them use anything like that, speaks volumes.
They are the same as me, suitable size diamond hole saw in a drill. Depending on the size of the hole, angle grinder.
Thanks for all the excellent advice.
I'll save my money and spend it more wisely on something that will do the job properly.
Just notice you said profiling..........you mean you want to put an edge on them. Mitre?
No, its more for cutting around door architraves and that sort of thing. I guess I could just cut the bottom of the architrave off instead !royaloakcarpentry wrote:Just notice you said profiling..........you mean you want to put an edge on them. Mitre?
- Has thanked: 2 times
- Been thanked: 28 times
toys for show, grinder for dough! I use my grinder for profiling, pretty easy and quick when you get the hang of it. I would definitely trim the architraves and slide the tile under, save your money on the bosch thing and buy a fein for trimming archs
- These users thanked the author haveagohero for the post:
- Technojunkie
Thanks for the info haveagohero.haveagohero wrote:toys for show, grinder for dough! I use my grinder for profiling, pretty easy and quick when you get the hang of it. I would definitely trim the architraves and slide the tile under, save your money on the bosch thing and buy a fein for trimming archs
Based on the excellent advice received on this thread I've definitely decided against the Bosch. Are your grinder and Fein the 240v or cordless versions ? I much prefer cordless but their so damn expensive !
Corldess are pretty gutless when it comes to tiling, ok for thin ceramic but will struggle with the porcelain. You need mains powered, ideally 110v but if you are diy then 240v will be fine.
- Has thanked: 1414 times
- Been thanked: 4019 times
Must be up to the job....It's a GTR....
That's good to know, thank you. I never work on site so will go for 240v.royaloakcarpentry wrote:Corldess are pretty gutless when it comes to tiling, ok for thin ceramic but will struggle with the porcelain. You need mains powered, ideally 110v but if you are diy then 240v will be fine.
- Has thanked: 379 times
- Been thanked: 584 times
I got the multi purpose hole saw kit, best I used for drilling mdf and i bought the carbide one to drill some holes in porcelain http://www.profitholesaw.com/3-the-prof ... troduction
- These users thanked the author transitboy for the post:
- Colour Republic
If you are in your own home then 240v is fine.
110v is for site and domestic. No excuse for a sole trader/company taking 240v tools into a domestic property.
I'd be very interested to know why !royaloakcarpentry wrote:No excuse for a sole trader/company taking 240v tools into a domestic property.
