Bathrooms galore
Razor
Has thanked: 483 times
Been thanked: 1251 times
Re: Bathrooms galore
Post by Razor »
Very nice work, sensible layout of tiling and looks like you matched the levels of the thinner mosaics nicely with the tiles surface, can't stand it when they're set back ::b
Looks like the grouting wasn't finished completely in the last pic?
darrenba
Has thanked: 104 times
Been thanked: 490 times
Post by darrenba »
Razor wrote:Very nice work, sensible layout of tiling and looks like you matched the levels of the thinner mosaics nicely with the tiles surface, can't stand it when they're set back ::b
Yes, luckily the mosaics were about the same thickness as the tiles. I usually advise the client to get tiles and border of a similar thickness if possible.
The grouting is complete in that pic except that it's grey and not white which makes it look slightly odd.
royaloakcarpentry
Has thanked: 39 times
Been thanked: 621 times
Post by royaloakcarpentry »
My top tip of the day.......
Thick tile and thin mosaic. Fix cheap thin contract tiles and then mosaic on top.
Megaross
Has thanked: 28 times
Been thanked: 110 times
Post by Megaross »
Cracking stuff, work to be proud of! :thumbright:
Crooksey
Been thanked: 72 times
Post by Crooksey »
royaloakcarpentry wrote:My top tip of the day.......
Stupid amounts of adhesive (keraflex), then float flat with a level and put mosaics in.
dave_39
Been thanked: 8 times
Post by dave_39 »
Excellent work there mate
Hitch
Has thanked: 77 times
Been thanked: 335 times
Post by Hitch »
I like the dark wood built in one.... what wood is it based on, assuming its a laminate?
All excellent work though :thumbright:
Return to “Show Case Gallery”
