Where to start tiling?
custom made
Has thanked: 10 times
Been thanked: 8 times
Post by custom made »
I have just tanked the shower area (800mm x 800mm) and it's now ready for the tiles to be fitted. My plumber is eager to fit the power shower, so I was thinking where the best place to start the tiling. Should I:
1. Fit the shower tray and tile & grout up from the bottom so that the plumber can come in at fit the power shower
or
2. Not bother fitting the shower tray yet and just tile and grout the area the power shower will be going, that way the plumber can come sooner and get his part of the job done
Andy
Has thanked: 1414 times
Been thanked: 4019 times
Re: Where to start tiling?
No 1.
custom made
custom made
Thanks wine~o
tictic
Has thanked: 5 times
Been thanked: 23 times
Post by tictic »
Power Shower......
You better leave the grout to cure for a few weeks prior to using the shower...or use an epoxy grout...
Check your grout mfr instructions for ......Power Shower!!
Agile
Gas/Heating Expert
Has thanked: 24 times
Been thanked: 294 times
Post by Agile »
There is a grey latex (?) liquid which can be used to paint over plasterboard or plywood before tiling to form a water proof layer.
What is this called? Brand names? Where can it be bought?
Tony
royaloakcarpentry
Has thanked: 39 times
Been thanked: 621 times
Post by royaloakcarpentry »
Fit shower tray and back fill between its tapered edge and the wall with silicone.
Tile, making sure the tanking is suitable for the combined weight of adhesive, tile and grout. (Some tanking systems are only capable of supporting a minimal weight).
Leave grout at least 24hrs before installing shower screen and silicone to internal corners around tray, ceiling and shower screen. Read instructions for shower screen, some are silicone inside only, some outside only and others are inside and 150mm up the outside.
Leave a further 24hrs before having shower installed. Get plumber to test it up into a bucket. Even though some grouts are a minimum 24hrs before manufacturers recommend use of the shower, I tend to advise my clients 2 weeks if they have another bathroom.
