just paid to have a shower enclosure tiled out using 6mm ceramic wall tiles, bonded using fast set flexible wall & floor tile addy and finished using flexible BAL grout. now found a very large crack in the grout line running from the top tile about 2/3rds the way straight down the wall
![What the ? :wtf:](./images/smilies/wtf.gif)
the tiler used is now saying that the wall system is to blame not him.....the walls are a metal track gyp line system, the shower cubicle area had been skinned with 12.5mm WBP ply which the tiler primed with SBR prior to tiling. if there was any doubt as the suitability i would have expected the tiler to say something BEFORE starting the work and not blaming it afterwards.....
he has said he will dig the grout out of the crack and regrout, as it maybe simply the walls "settling". all this seems a little BS to me, if there is a crack now then i suspect it is likely the crack will appear again in the future.....
without going to the extreme of ripping all off the wall and wasting hundreds of pounds, is there anything else that can be done????
cheers
scraggy
