Installation of a PSU
Nobby01
Has thanked: 4 times
Post by Nobby01 »
I have watched 'Ultimatehandyman's, 'youtube' video with great enthusiasm. Thank You.
However, I never noticed the Connection Leads which I have being installed?. These are:-
A Multiple set of 4.leads.I believe they come under 'Peripheral Sata'?. The Leads I disconnected from my Recent Broken Down PSU unit came from what looked to be a set connected to the case Front & rear?.. There was 1.Yellow,2. Black,1.Red.These cables ran to a Large connector,as well as a Much smaller one.I got no problem with the Larger connector.ONLY, the smaller one.As I do not really know where it came off of? Can you help Please?
aeromech3
Has thanked: 177 times
Been thanked: 665 times
Re: Installation of a PSU
Post by aeromech3 »
PSU's come with spare leads to fit a multiple build, I too have a small flat plug left over at the end of a multi power lead with same colours it could be the 4 pin to power to a floppy disc drive.
Nobby01
kellys_eye
Has thanked: 357 times
Been thanked: 1790 times
Post by kellys_eye »
The unused connectors are simpy left disconnected. Tie them out of the way.
These users thanked the author kellys_eye for the post:
Nobby01
Megaross
Has thanked: 28 times
Been thanked: 110 times
Post by Megaross »
Yeah, if it can be connected somewhere, connect it.
If not just tie it out the way.
If your pc turns on you did it right.
Return to “Computers”
