What thickness ply
CHIPPYAL
Has thanked: 51 times
What thickness ply
Post by CHIPPYAL »
Fitting a kitchen shortly that needs the floor tiled, it runs from floorboards through to concrete conservatory.
What thickness ply should I lay and what fixings
many thanks
Al
Colour Republic
Has thanked: 263 times
Been thanked: 544 times
Re: What thickness ply
Post by Colour Republic »
Minimum for floor is 15mm as per BS5385 but is fairly hard to get hold of so most opt for 18mm. However if the floor is deflection free you can use tile backer boards at a minimum of 6mm. You will need to provide an expansion joint at the change of substrate though.
CHIPPYAL
Post by CHIPPYAL »
Is the expansion joint needed for the ply as well or just the backer boards?
Colour Republic
for the ply as well.
If you go down the ply route then the ply needs to be primed on the reverse as well as the face. My option would be to opt for tile backer boards unless there was a very specific reason to use ply.
CHIPPYAL
Post by CHIPPYAL »
Only thinking that it would be cheaper, I will investigate the cost of the backer board
thanks
Al
Colour Republic
they are similar sort of price to be honest
CHIPPYAL
Post by CHIPPYAL »
Thats cool, to be honest its got to be tiled under the appliances so 6mm would mean i dont have to raise the kitchen as much as with the ply.
what do you stick the backerboard to the concrete with
al
Colour Republic
tile adhesive
These users thanked the author Colour Republic for the post:
CHIPPYAL
