Got a glass splashback to fit behind a free standing cooker, 900 x 700 onto new plasterboard.
Going to fit a slim batten below cooker level to support the glass, what prep do you recommend for the plasterboard and what adhesive would you use to hold it in place?
Glass Splashback
- 54aardvark
- Has thanked: 16 times
- Been thanked: 56 times
- aeromech3
- Has thanked: 177 times
- Been thanked: 665 times
Re: Glass Splashback
Hi, bit of thread reading on subject whilst waiting for a full answer to prep work.
http://is.gd/9gclN6
http://is.gd/9gclN6
- 54aardvark
Thanks for the link, confirms what I thought re adhesive, I think Zinsser GARDZ would be OK for sealing the plasterboard - soon know if it falls off!
There are no problems - only solutions
- Has thanked: 39 times
- Been thanked: 621 times
You can stick straight onto the plasterboard. never seen it sealed before hand and never pulled a splashback or mirror off from a sealed plasterboard. So if they stay put for 20 years without sealing, it must be fine.
