Knackered my Saw?
- Hoovie
- Borders Bodger
- Been thanked: 4 times
Bahco Saw talk
Just thought I would update this thread ... started to do my floor today and I bought the saw recommended below by Carhartt Kid in readyness.
It is absolutely superb - It goes through the laminate like butter. I was going to use a mitre power saw to cut the planks to length for ease, but with this saw, it takes just 10 seconds to slice through it. It is just as good for doing a trim right down a full length.
Highly recommended
Highly recommended
carhartt kid wrote:I use a Bahco Laminator hand saw for all laminate now. Cuts super fast
BAHCO Superior Hard Point Laminator Handsaw
20" (508mm). Thick blade makes for stable, straight cuts through laminate flooring and improved cross and rip cutting. Excellent for cutting wet timber. Fine cut. 11tpi.
* XT Hardpoint Teeth
* Triple-Ground
* Ergonomic Bi-Component Handle
* Low Friction Powder Coating
About £11 from screwthicks or beancue!!
