Metal cutting saw
Hitch
Has thanked: 77 times
Been thanked: 335 times
Metal cutting saw
Post by Hitch »
Spotted this yesterday, metal cutting circular saw, very similar to the evolution ones.
Not used this particular one, but will probably order one very soon.
http://www.ebay.co.uk/itm/390534803952? ... 97.c0.m619
Bought from FFX tools before, good service too.
moderator6
UHM Super Moderator
Has thanked: 141 times
Been thanked: 362 times
Re: Metal cutting saw
Post by moderator6 »
Hitch
Post by Hitch »
Most places seem to sell them for iro £150.
Only think i havn't checked, is the replacement blades, Evolution ones are readily available, but i'm unsure if the bore is the same....
FFX
Has thanked: 6 times
Been thanked: 37 times
Post by FFX »
Only just seen this - the blade that comes with it has a 20mm bore. I'll get a box tomorrow and check to see if there is a collet to reduce that bore diameter from something bigger or not.
Regards
Ian
(PS if you go to the website it will be cheaper still)
FFX
Post by FFX »
Just had a look, it is definitely a 20mm bore and it doesn't have anything to enable you to use other size bore blades with it.
Regards
Ian
Hitch
Post by Hitch »
Nice one Ian, pretty sure the evolution and alfra blades are 20mm bore. They tend to be readily available.
I will get one next month then...blew me tool budget on a mitre saw from you last week. One of the Hitachi sliding ones. Awesome saw for the money.
Return to “Bargain Tools”
