Tile Arrangement
Tile Arrangement
Hello,
I'm wondering if some of the experts can help me choose a good layout for me tiling my bathroom floor.
My tiles are 60x30 (which in reality is 59.4 x29.5)
The bottom of the door frame is around 69cm.
I like the idea of doing a staggered arrangement to break up any forced long lines, in such a small space. But I can't seem to work out a good layout that doesn't give me stupid off cuts horizontally between the wall and the bath.
Thanks in advance!
Thanks in advance!
- ayjay
- Has thanked: 458 times
- Been thanked: 1708 times
Re: Tile Arrangement
On a diagonal can look good in small spaces - better with square tiles though.
It depends if you what to give it contemporary look, doing a brick pattern would be best for your large tiles. Don't forget, what you cut off from one side u will be able to use on the other side of the next row. I notice you have the tiles butted up against the wall, professional tilers won't do this and center the tiles so both sides are cut as walls never run true so the tiles will look like they are running off at an angle.
Hope this helps
John
Hope this helps
John
Thanks for the replies.
Not to keen on the diagonal, as I would have to cut every tile into a square.
RE: butted up against the wall - I'm planning on leaving a 10mm space (wall tile) + 3mm spacer... That's the correct way right?
RE: center the tiles so both sides are cut - not sure what you mean by this?
- philprime
- Has thanked: 77 times
- Been thanked: 247 times
What he means is messure and mark the center if the room and start tiling away from it so all the cuts will be made on tiles next to the wallcolouredFunk wrote: RE: center the tiles so both sides are cut - not sure what you mean by this?
Also will look better in the eye when finished
ah I see. So flip the arrangement of what I've done above around, so the thin cuts are by the wall and not the bath panel.
- Has thanked: 39 times
- Been thanked: 621 times
The bath is irrelevant. It only matters if you end up with a ridiculous rip of tile before the panel.
Set it out to centre of door opening and see what rip that gives you to the left hand and right hand walls.
The focal point of that room is drawing you from the door opening down to the window.
