Tile over hole in the wall?
I have had an old heating clock removed from my kitchen which was located in the middle of a tiled wall. I have some spare tiles I can fit but I have a gaping hole in the wall as per the attached picture. Will I need to put some plasterboard over this?
- image.jpg (241.18 KiB) Viewed 1446 times
- Has thanked: 39 times
- Been thanked: 621 times
Re: Tile over hole in the wall?
Yes and no.
Depends on the tile size compared to the hole size and also where the tile joint falls in relation to it.
4 tiles fills the entire space. The bottom right tile will have to be cut in a reverse 'l' shape to fit around the switch plate. 2 tiles to the left abut the hole by about half an inch
Sounds like it should be ok. Just be careful when tightening the screws on the face plate.
