Acer Aspire 5735Z.
Right cursor key has stopped working. It did this a while ago and then, for some inexplicable reason, it started working again. It's now stopped - AGAIN
It's not a hardware fault and this has been reported across the interweb as a common problem but there seems to be no specific solution for my model (all the answers give you help to get around the issue but I want the actual key to work).
Running Windows 7
Any idea?
Dodgy keyboard key (just the one!)
- kellys_eye
- Has thanked: 357 times
- Been thanked: 1790 times
- BillyGoat
- Troll Headbutter
- Has thanked: 386 times
- Been thanked: 796 times
Re: Dodgy keyboard key (just the one!)
Not hardware? Sure about that?kellys_eye wrote:Acer Aspire 5735Z.
Running Windows 7
Any idea?
Turn PC on and enter BIOS as soon as it comes on (F2, Delete, whatever it tells you). If it's NOT software, you can use arrow key to navigate.
If it works, it's OS related. If it don't, it's hardware - simple.
Try take KB off by disconnecting ribbon, attach. That's about your lot. Wouldn't be the first hardware fault to be common across a range.
BG
- Has thanked: 1414 times
- Been thanked: 4019 times
BillyGoat wrote: Wouldn't be the first hardware fault to be common across a range.
BG
Especially on an Acer Aspire.. I had one..once.
- BillyGoat
- Troll Headbutter
Built to a budget WO.....not typically a high end machine.
Also, if you think it's typically Sainsburys/supermarket quantity of sales (where did you get it? They 'fell out' with a certain retailer a while ago), then you'll hear more faults as there are TONS of them out there.
BG
BG
- kellys_eye
Well it would appear that it's a hardware fault as the cursor key doesn't work under the BIOS screen - thanks for the tip BG - but funny it should suddenly work (for abot 3 months) before stopping again
It's not worth the effort of taking the keyboard apart (if it's a broken track - probably a pth breakdown - I could fix it easily) but other than this issue the lappy has worked flawlessly. It's actually quite speedy! Ah well, if I get bored over winter I might have a closer look at it.
Cheers
Cheers
- BillyGoat
- Troll Headbutter
16 clams new: http://www.ebay.co.uk/itm/NEW-GLOSSY-UK ... 232b0f5c1f
- UHM Super Moderator
- Has thanked: 141 times
- Been thanked: 362 times
BillyGoat wrote:16 clams new: http://www.ebay.co.uk/itm/NEW-GLOSSY-UK ... 232b0f5c1f
Funniest ebay ad for ages:
PLEASE CHECK THE PICTURE OF THE KEYBOARD THIS IS THE EXACT ITEM THAT YOU WILL BE RECEIVING
A 100% Compatible model will be sent if the exact part number isn’t in stock
