This week I have been working on this yard. Knackered old paving and a bloody great ugly oil tank right in view.
The lady was on a tight budget, but the slabs needed a better sub base as they were moving all over the place.
So, the yard as was.....
And now, with all the old slabs relayed on a 100mm compacted MOT sub base - had to replace just 8 slabs, so dotted them about to create a random colour scheme.
The oil tank hidden with some bamboo screening for £45, framed with some treated lath....
Before:
And after:
The customer is going to do the lath framing in cedar to match the fence, then when my grout joints are fully hardened she is going to pressure wash the old slabs with some patio cleaner to get it all sparkly !
Ugly yard made better....
- Cannyfixit
- Has thanked: 102 times
- Been thanked: 183 times
Re: Ugly yard made better....
Nice job,wont know the new ones are there once its been pressure washed
- Chappy
- Has thanked: 133 times
- Been thanked: 205 times
Yes, although I quite like the different shades as it is.
When I lifted up the old patio, I found a manhole that had been slabbed over!
The homeowner had no idea it was there......and no, I haven't slabbed back over it, its just out of shot! Unbelievable what some people will do.
- Has thanked: 1415 times
- Been thanked: 4024 times
Nicely done Chappy I wouldn't go jet/power washing that though....you'll only remove the newly done pointing..
Just get some Jeyes patio/path cleaner and a stiff brush......
- nick200
- Has thanked: 409 times
- Been thanked: 222 times
Looks loads better and hard to tell that it is the same yard
Nick
- Chappy
Okey Dokey, thanks. The customer is going to do it, so I'll pass that on, cheers.wine~o wrote:Nicely done Chappy I wouldn't go jet/power washing that though....you'll only remove the newly done pointing..
