stainless steel splashback in kitchen
petersprings
Post by petersprings »
Hi all,
Asking this question on behalf of my sister and her other half. they're re-doing the kitchen and are getting a new cooker but want something to go behind it.
as far as they can tell a steel splashback is the best option for longevity and it looks good too. has anyone got any experience with these? are they any good? and how easy are they to install?
thanks
philprime
Has thanked: 77 times
Been thanked: 247 times
Re: stainless steel splashback in kitchen
Post by philprime »
Stainless steel splash backs look very nice they are easy to fit most come with a mdf backboard I normally use grab adhesive to fix to wall
Hitch
Been thanked: 335 times
Post by Hitch »
Off the shelf ones are pretty cheap, but look okay.
As above, an off the shelf one will come with an mdf core, just gripfill nice and evenly to the wall.
If they are having stainless hood or cooker, try and get one to match from the manufacturer, otherwise it may be a different grip polish ....a bit anal, but does show in certain light... most stuff is 320g.
As for cleaning, nothing abrasive, and wipe with the grain direction
petersprings
Thanks for the advice both!
They have a bit of an awkward space by the looks of it, so they're looking around for somewhere to get a splashback cut to size.
Anyone have any suggestions?
Hitch
Post by Hitch »
Bespoke ones, theres a few options there....
You can get a bit of flat stainless sheet, and attach it to a thin board to space it out to match tiling etc.... or attach straight to a wall....
Other option, is to have a small fold put in the sides of it, to give a nice radiused edge as the off the shelf ones tend to be. Only needs about a 6mm inside fold then a bit of 6mm ply or mr/mdf can be used as a backer, this will be the price of the sheet plus in the region of £20-40, dependant on how many folds they go with....2 sides will be cheaper than 4.
Probably best to find a local sheet metal work place, and ask for a price of a bit just cut to size...
Ask DP1 finish, with polycoat on, specify its for a splashback, any you/they dont want any scratches.
I'd be inclined to ask for 1.2mm thick personally... some will do 0.9mm, and the off the shelf stuff is often thinner still....
Now, with very thin sheet, when you gripfill onto a wall, as the adhesive shrinks, if you just do it in big dollops, you can end up with ripples that reflect the light and makes it look rubbish. If they have a stock of suitable offcuts, it may end up cheaper to have a thicker bit, rather than have them get a sheet in for it.
Out of interest, where are you/they?
aeromech3
Has thanked: 177 times
Been thanked: 665 times
Post by aeromech3 »
Just an idea, as I have used them in other applications, you might get away with a stainless "door kick plate"!
petersprings
Thanks again for the advice. I've found a place online that does the right size for around £50, with the right finish and it can drill holes if they decide to fix it this way.
Does that sound reasonable?
Hitch
Post by Hitch »
Sounds good to me!
TSummerlin
Has thanked: 3 times
Post by TSummerlin »
Sounds good to me too. Give it a go and let us know how it goes!
