Oak Doors
- Has thanked: 10 times
- Been thanked: 8 times
Re: Oak Doors
I want to try fox wedging on this door and when I think about I haven't left myself any room really for normal wedges.custom made wrote:DWD
wedging still to come
- getthewheelsinline
- Has thanked: 224 times
- Been thanked: 182 times
- Has thanked: 814 times
- Been thanked: 3508 times
Re: Oak Doors
I think that it is safer wedging as that door is going to take a bit of weight in glass and a lot is dependent on the four M&T's holding true. To save typing the obvious, I found this which is quite useful http://americanwoodworker.com/blogs/tec ... tenon.aspx
I like the hole drilled in the tenon that prevents spitting in this example. Worth a bit of tinkering to get it as strong as you can.
Re: Oak Doors
I think the point I wanted to make most was that if there is any shrinkage or expansion in the joint it could create a degree of movement that would allow the door to drop a tad and cause issues. As you are using through M&T's you can wedge it up nice and tight and also make a feature out of it showing the joint.
Victorian doors were often made simply wedged together with no glue and it is possible to pull them apart 150 years on. I saw this on telly once with Tommy Walsh and a bloke called Will Mockett. Cannot recall the show though.
- Has thanked: 1 time
- Been thanked: 69 times
Re: Oak Doors
Nice job. I was going to ask what method you use to cut the tennons but see you use a saw. Do you cut them on the De Walt SCMS or a Radial arm saw? Reason I am asking is on a SCMS you have to pack the timber out to get the cut level across the face of the tennon.
Never enough hours in the day!
http://www.alanwilley.co.uk/
Re: Oak Doors
Mailee
I used my table saw for the tenons and then chisled off the rest od the waste. I then used the router table fitted with a straight bit to get a nice clean finish on the tenon
I was going to wedge up the door last night but only managed to cut the tapered mortice and drill relief holes in the tenons. I'll (hopefully) get around to cutting the wedges and gluing the door tonight!
- Relief holes drilled with 6mm bit.JPG (98.17 KiB) Viewed 5831 times
- 87 Degree Block for cutting tapers in mortice with chisel.JPG (123.83 KiB) Viewed 5831 times
- 3mm line marked out for taper.JPG (89.6 KiB) Viewed 5831 times
Re: Oak Doors
Finally got around to gluing, wedging and clamping the first door. The fox wedges working out really well and I'm going to use this wedging method on the next door.
Hopefully I'll start the 2nd door tomorrow.
- Wedges cut form table saw.JPG (137.25 KiB) Viewed 5806 times
- Top rail (glue).JPG (91.88 KiB) Viewed 5806 times
- Clamped bottom rail.JPG (114.04 KiB) Viewed 5806 times
- Clamped bottom rail 2.JPG (100.91 KiB) Viewed 5806 times
- Clamped bottom rail 1.JPG (109.37 KiB) Viewed 5806 times
Re: Oak Doors
I'm not trying to teach you how to suck eggs but I think you will find Fox wedges are different. Those are just wedges, a fox wedge is one that is invisible to the outside and bottoms on a blind mortice. I used to make the same error in calling those fox wedges that's how I know.
Re: Oak Doors
I hear what you're saying it Mailee and agree Still, I would think this method of wedging is stronger than the standard method of wedging a m&t on a door stile.
- Has thanked: 735 times
- Been thanked: 2339 times
Re: Oak Doors
thats the trouble with working on your[our] own we get confused pick up the wrong terminolligy with no one to correct usmailee wrote:I'm not trying to teach you how to suck eggs but I think you will find Fox wedges are different. Those are just wedges, a fox wedge is one that is invisible to the outside and bottoms on a blind mortice. I used to make the same error in calling those fox wedges that's how I know.
Re: Oak Doors
I totally agree with you. Add to that the fact that you are not just relying on the glue but a mechanical joint too so will be a strong joint for many years to come.
Re: Oak Doors
I have been away the last few months with work hence my lack of activity. Finally got the doors finished. Will forward pics with architrave complete shortly.
- With glass and lacquer
- Double Doors (1).JPG (153.1 KiB) Viewed 5429 times
- Without glass or lacquer
- Double Doors.JPG (106.67 KiB) Viewed 5429 times
- These users thanked the author custom made for the post:
