Remove a tile advice
bgatty68
Has thanked: 21 times
Been thanked: 5 times
Post by bgatty68 »
:oops: :oops: :cb :cb can someone give me some advice please on removing a tile, I have tiled around a window recess and noticed that one of the tiles is just not right and sits too proud so is slightly further out than the other tiles around the window recess and adhesive has set as i done the most stupid DIY mistake and thought i would get away with it :oops: :oops: :oops: but it looks rubbish so I would like to remove it without damaging any of the others any advice would be great
toolbox
Has thanked: 128 times
Been thanked: 210 times
Re: Remove a tile advice
Post by toolbox »
Use a masonary drill stick tape over the tile to stop the drill slipping and pepper it with holes, then you can break it out in small bits.
Edit Wear eye protection !
nick200
Has thanked: 409 times
Been thanked: 222 times
Post by nick200 »
We did similar to toolbox, except we raked out the grout first (grout rake, ours was from Wickes) then we drilled and used a chisel.
As per toolbox, eye protection is a must!
Nick
DIY_Johnny
Mr. Grumpy
Has thanked: 25 times
Been thanked: 109 times
Post by DIY_Johnny »
I have done this a several times now but in my view its a must to rake the grout out first, as loose adjacent tiles can start to chip and lift.
I never bother drilling holes, just use a bolster chisel and tap away. Had no problems so far
The BOSCH 180E with the RIFF Tungsten Carbide Sawblade attachment is great for removing the grout but wouldn’t buy one especially for the job. Unless you want to treat yourself
:cheers:
toolbox
Post by toolbox »
Yes I missed the bit about cleaning out grout :oops:
Also keeps the mess down if you hold a rag over the tile as you prise the bits out.
DIY_Johnny
Mr. Grumpy
meant to say batty,
have you grouted yet? I thought my tiling was rough but grouting made a big difference. But like you, I know exactly where I messed up a few up and I notice it every time. No-one else does though!
The man with no aim
Has thanked: 5 times
Been thanked: 41 times
Post by The man with no aim »
DIY_Johnny wrote:meant to say batty,
Ain't that the worst thing about DIY, you always see the errors, nobody else does but, it don't make you feel any better about it.
Regards
T
bgatty68
Post by bgatty68 »
cheers guys for that, will get my eye protection out for this one then
"DIY_Johnny"]meant to say batty,
who is this guy batty :dunno: :lol: :lol: :lol:
is my mum Nora :lol: :lol:
bgatty68
Post by bgatty68 »
thanks for the tips guys, old tile removed and new one fitted last night :thumbleft: :thumbright: :salute:
These users thanked the author bgatty68 for the post:
FatHands
