Watch out for DANGEROUS LED bulbs.
Energy saving questions in here please
BillyGoat
Troll Headbutter
Has thanked: 386 times
Been thanked: 796 times
Post by BillyGoat »
If you've got some cheap LED bulbs similar to this, hope it's of use - I'm a sucker for a bargain, but some of the recent lights I've seen have made me think twice about where and how much I pay for them!
Saw this and thought I'd share in case it helps anyone. I can honestly say I've NEVER turned a circuit off to change a bulb and perhaps I will in the future - stay safe!
BG
Has thanked: 1415 times
Been thanked: 4024 times
Re: Watch out for DANGEROUS LED bulbs.
:shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock:
kellys_eye
Has thanked: 357 times
Been thanked: 1790 times
Post by kellys_eye »
Should we be surprised? Given the price they sell them at there just HAS to be a compromise in there somewhere - even a lethal one so it seems! :shock:
I suspect the only difference between the cheap chinese knockoff and 'legit' LEDs would be some insulation between that PCB and the outside world. The voltage dropping circuit is pretty much de-rigur for the device.
Has thanked: 736 times
Been thanked: 2341 times
as an aside
is there any difference in efficiency between a led bulb rated at say 85-240v over a 220-240v or does it depend :dunno:
kellys_eye
If the LED is built using the capacitor-dropper method then the components should be calculated to run the LEDs at their rated current at the maximum operating voltage. At lower voltages the LEDs will be under-running thus 'saving power' but at the expense of light output - although you'd probably be hard pressed to notice the difference by eye alone.
ok cheers so at uk mains makes little difference consumption and output wise :dunno:
kellys_eye
One would HOPE that they were designed such that max light output was for our local voltage - if they designed it for the LOWER voltages then running it at 240V would be OVER RUNNING them.
Like I said, designing them for the higher (i.e. our) voltage only means a very slight reduction in brilliance when running at say 110V.
There should be no difference in operation between the LEDs marked 85-240 and ones marked 240V only assuming they were both running at 240V
Return to “Energy Saving”
