Decking project 2013
Call-Joe
Has thanked: 1 time
Post by Call-Joe »
Last summer I was asked to look at what can only be described as a rather nasty large hole at the rear of a friend garden, it had a very poorly willow tree that had been damaged by wire and nails over the years.
I had the tree removed and the roots killed.
As you can see the hole had slopping sides and needed to be shored up, after building a block retaining wall I dug 16 holes and concreted 16 posts to take the decking framework.
This was all bolted up with galvanised coach bolts, the tops of the post were removed and then the decking could go down nice and level, with the decking down and some new fencing and trellis all that was needed was the summer house to finish it off, now you would never know the hole had been there and it make for a very nice place to sit and relax.
Joe
Removed. Mod 2.
moderator2
UHM Super Moderator
Has thanked: 155 times
Been thanked: 569 times
Re: Decking project 2013
Post by moderator2 »
:welcomeuhm:
Members are only allowed to promote their websites after making 100 posts offering help and advice.
Check out the Forum Rules before attempting to promote your website. Forum Rules, read them all but especially the section entitled 'Self Promoting Links'
The link to the website that you posted has been removed, consider this to be a final warning until you have made 100 useful posts.
Admin & Mods
These users thanked the author moderator2 for the post:
Call-Joe
Call-Joe
Has thanked: 1 time
Post by Call-Joe »
Thank you for that, I didn't know.
I had tried to post some pictures but as I am new to this I have not worked out how.
Any tips please?
moderator2
UHM Super Moderator
You may need to resize the pics first. Maximum of 1200 pixels.
Then click on the *Full Editor* box at the bottom of the reply box.
Then click on *Browse*
Select the image you want to attach and click *Add the file*
Repeat for more pics. When happy click *Submit*
Call-Joe
Has thanked: 1 time
Post by Call-Joe »
Many thanks
Call-Joe
Has thanked: 1 time
Post by Call-Joe »
Ok I have worked out how to post pictures lol
Decking 4.JPG (545.88 KiB) Viewed 4174 times
Decking 3.JPG (481.85 KiB) Viewed 4174 times
Decking 2.JPG (388.64 KiB) Viewed 4174 times
Decking 1.JPG (528.04 KiB) Viewed 4174 times
philprime
Has thanked: 77 times
Been thanked: 247 times
Post by philprime »
Looks good did you have to apply for planning permission
Has thanked: 1415 times
Been thanked: 4024 times
:welcomeuhm:
Not sure that the idea of running all the boards to finish at the same point (Pic1) is a good idea, normally the boards are laid in a "Brick pattern"...
Call-Joe
Has thanked: 1 time
Post by Call-Joe »
I didn't need planning and I finished the boards like that as I was going of en existing deck that had been down a couple years before I moved in
Return to “Show Case Gallery”
