I am a vey good DIY person and I have been work on my house since December and doing a complete renovation and I think it should be ok just wanted some advice as I though 5.5mm was thin but since I install my new t & g floor boards it seem really sold with no movements on your feet, so I thought upping it to 9mm plus the 18 floorboards would make it 27 mm .
So how many screws would you use and how far apart
Sent from my iPhone using Tapatalk
Tiling a bathroom floor ply wood size??
- Has thanked: 1414 times
- Been thanked: 4019 times
Re: Tiling a bathroom floor ply wood size??
IF I was doing it and had no choice..then I would be using 60mm screws into the joists every 300mm.wine~o wrote:I stand by what I said earlier. No-one is going to say "yes, 9mm will be fine" it might be OK, it might not be.
Flexible tile adhesive. And if I was doing it for a customer...I would not give any guarantee .
- philprime
- Has thanked: 77 times
- Been thanked: 247 times
T&G floorboard will expand and contract over time like all timber does that's why others have said ply
5.5mm ply is far to thin 18mm plus is much better but I can understand you don't want to rip up new flooring but you are the one who has to live with it at the end of the day
- Has thanked: 39 times
- Been thanked: 621 times
(I wouldn't) but if I were chancing my arm on a job then I would be inclined to up the percentage of it not failing by a small margin by using BAL Fastflex adhesive.
It will only give yo a small margin of improvement. Better off to get the background correct though.
