big-all wrote:are you planning on a part open back if not what have you planned for the cables and leads??
remember scart leads need around 70mm from the back off a machines for clearance
You seriously need to update your gear BA
really not worried about high definition with 60 year old eyes and ears there is no such thing
excellent fit and nice job
but before your final tinkering place the cabinet in place as the actual setup and clearances will will be goverened by how level the floor is
Yes I won't be going any further until the unit is assembled and in place. I find getting the hinges done at this point makes it a lot easier. I could have used blum hinges which would have made my life a lot easier but for this project I prefer the look of the mortise hinges on the front.
Managed to get the oak top machined up last night. The top is 450 width x 2100 length x 20mm thickness. I've numbered the boards (which you probably can't see) in the sequence I want them to appear when I glue up. I'm also going use biscuits to join each board.
Some more photos. I've a few things left to do such as fitting skirting to the base of the unit and two slips to fit to the front of the unit. I can then give a final finish sand to everything and apply base coat and lacquer.
That looks fantastic CM, good job.
For the top, did you use Sash clamps for the glue up? I'm new to woodworking and need to buy clamps as I don't have any, however clamps arent cheap when you need to buy 5/10 for a table top, so I want to make sure I buy the correct ones!
Yes I used sash clamps (see photo) for the glue up, 6 in total. If you can stretch your budget I would recommend purchasing t-bar clamps. The are more expensive but are a lot easier to use. Sash clamps have a tendency to fall over when you are trying to clamp your work. T-bar clamps stay upright and the steel is very straight and rigid compared to sash clamps.
