Poplar & Oak Cabinet
Has thanked: 735 times
Been thanked: 2339 times
Re: Poplar & Oak Cabinet
moderator6 wrote:
big-all wrote:are you planning on a part open back if not what have you planned for the cables and leads??
remember scart leads need around 70mm from the back off a machines for clearance
You seriously need to update your gear BA :lol: :lol: :lol: :lol:
really not worried about high definition with 60 year old eyes and ears there is no such thing :lol: :lol:
royaloakcarpentry
Has thanked: 39 times
Been thanked: 621 times
Post by royaloakcarpentry »
custom made wrote:
royaloakcarpentry wrote:Ha ha...you know me too well.
Shame cos he knows how to do joinery.
I could have used biscuit/dowell joint but thought as it wouldn't be seen I would just use pocket holes :-) Lazy way out of doing the face frame as well
For a moment I thought it was going to read mortice and tenon.
custom made
Has thanked: 10 times
Been thanked: 8 times
Post by custom made »
Doors
custom made
:wink:
custom made
More photos. Fitting hinges to doors.
Some slight adjustments required here but still a good first fit
excellent fit and nice job :lol: :lol:
but before your final tinkering place the cabinet in place as the actual setup and clearances will will be goverened by how level the floor is
custom made
Hi BA
Yes I won't be going any further until the unit is assembled and in place. I find getting the hinges done at this point makes it a lot easier. I could have used blum hinges which would have made my life a lot easier but for this project I prefer the look of the mortise hinges on the front.
:thumbright:
custom made
Finally finished hanging all the doors to the face frame. I'll start on the carcass this evening
custom made
Another few photos. Didn't manage to get much done with this in the last week, hopefully I'll get it finished this weekend.
Dado
Dado
custom made
Managed to get the oak top machined up last night. The top is 450 width x 2100 length x 20mm thickness. I've numbered the boards (which you probably can't see) in the sequence I want them to appear when I glue up. I'm also going use biscuits to join each board.
custom made
Some more photos. I've a few things left to do such as fitting skirting to the base of the unit and two slips to fit to the front of the unit. I can then give a final finish sand to everything and apply base coat and lacquer.
Has thanked: 820 times
Been thanked: 3519 times
Are you still going to paint the base part? I like your corner cramp solution :thumbright:
custom made
Hi DWD
Thanks.
Everything except the oak top with be cream/white, I'll use an ac laquer on the oak.
mikeday1991
Post by mikeday1991 »
That looks fantastic CM, good job. :thumbright:
For the top, did you use Sash clamps for the glue up? I'm new to woodworking and need to buy clamps as I don't have any, however clamps arent cheap when you need to buy 5/10 for a table top, so I want to make sure I buy the correct ones!
custom made
Hi Mike
Yes I used sash clamps (see photo) for the glue up, 6 in total. If you can stretch your budget I would recommend purchasing t-bar clamps. The are more expensive but are a lot easier to use. Sash clamps have a tendency to fall over when you are trying to clamp your work. T-bar clamps stay upright and the steel is very straight and rigid compared to sash clamps.
Return to “Show Case Gallery”
