Work photos....
- Has thanked: 28 times
- Been thanked: 69 times
Work photos....
Jumping on the bandwagon thanks to Stevies tip about resizing photos. Nothing interesting on my new phone will try to get some off my 4s.
Just started the barn conversion this week will update as work progresses.
Cheers
Cheers
- Traditional build floor
- image.jpg (565.97 KiB) Viewed 4710 times
- Porch
- image.jpg (500.01 KiB) Viewed 4710 times
- Loading up ff panels
- image.jpg (493.72 KiB) Viewed 4710 times
- Trusses up
- image.jpg (379.6 KiB) Viewed 4710 times
- Valley detail
- image.jpg (395.71 KiB) Viewed 4710 times
- Timber kit complete
- image.jpg (389.37 KiB) Viewed 4710 times
- Fascia on
- image.jpg (414.3 KiB) Viewed 4710 times
- Traditional build roof
- image.jpg (493.08 KiB) Viewed 4710 times
- 2 new builds from last year
- image.jpg (397.41 KiB) Viewed 4710 times
- Shell
- image.jpg (233.78 KiB) Viewed 4710 times
- Loaded up and sole plate down
- image.jpg (307.71 KiB) Viewed 4710 times
- External panels made up and building paper fitted to cold side
- image.jpg (247.59 KiB) Viewed 4710 times
- Insulation in
- image.jpg (300.25 KiB) Viewed 4710 times
- Internal layout set out
- image.jpg (297.83 KiB) Viewed 4710 times
- Insulation in and subfloor down
- image.jpg (327.04 KiB) Viewed 4710 times
- These users thanked the author 182michael for the post (total 2):
- steviejoiner74 • big-all
- Rating: 14.29%
- steviejoiner74
- Has thanked: 747 times
- Been thanked: 1616 times
Re: Work photos....
Cheers for sharing! You've surely mastered the resizing better than me as the photos are nice and clear
- ayjay
- Has thanked: 458 times
- Been thanked: 1708 times
Re: Work photos....
Resizing to a smaller pic is only likely to make them sharper, you need to hold the camera steady first though.steviejoiner74 wrote: You've surely mastered the resizing better than me as the photos are nice and clear
- steviejoiner74
Re: Work photos....
By reducing the pixels by over half does that not make the image worse??ayjay wrote:Resizing to a smaller pic is only likely to make them sharper, you need to hold the camera steady first though.steviejoiner74 wrote: You've surely mastered the resizing better than me as the photos are nice and clear
- ayjay
Re: Work photos....
Not as far as I know.steviejoiner74 wrote:By reducing the pixels by over half does that not make the image worse??ayjay wrote:Resizing to a smaller pic is only likely to make them sharper, you need to hold the camera steady first though.steviejoiner74 wrote: You've surely mastered the resizing better than me as the photos are nice and clear
Blow a picture up to twice the size and it will almost certainly look worse - you can get away with blowing up a picture if it's really sharp to start with but there is still a limit: reducing a pic won't make it less sharp.
It might be dependant on the software used, I only use freebie programmes available on the net, I have no experience or knowledge of phone cameras at all.
- steviejoiner74
Re: Work photos....
It said the pic was 3600 x 2600 pixels(roughly) so I reduced it by quite a bit to fit here. I know what you mean by making it bigger it should be of less quality but I'm getting confused now as I've reduced the pixel count which should make it smaller but of less quality as well?? Would cropping the photos be better?
- UHM Super Moderator
- Has thanked: 141 times
- Been thanked: 362 times
Re: Work photos....
Reducing the pixel count is fine if you're making the picture smallersteviejoiner74 wrote:It said the pic was 3600 x 2600 pixels(roughly) so I reduced it by quite a bit to fit here. I know what you mean by making it bigger it should be of less quality but I'm getting confused now as I've reduced the pixel count which should make it smaller but of less quality as well?? Would cropping the photos be better?
- steviejoiner74
Re: Work photos....
Basically I'm rubbish at taking photos then
- Has thanked: 736 times
- Been thanked: 2341 times
Re: Work photos....
very interesting nice job thanks for sharing them
- These users thanked the author big-all for the post:
- 182michael
