- Ultimate Handyman Forum Index TOOL FORUM Bargain Tools
- It is currently Thu Feb 27, 2025 6:04 am
Which Diamond Cutting Discs?
Dear All,
This is my first posting here. I look forward to contributing as well as seeking help and guidance here. I am retired and a keen DIY enthusiast.
I have just purchased a 115mm Black and decker angle grinder. It is not new but has hardly been used and came boxed with the user manual and two unused resin grinding discs . I hope initially to use the angle grinder,very gingerly, when I do some patio paving soon.
I did some reading on line re what disc do what etc including watching your very own good video.Most helpful.
My question is, while I accept you get what you pay for, I saw some discs advertised at very low prices. I am particularly drawn to the Silverline (#394779) 115mm Diamond cutting disc @ £3.67 each. It is supported with many good user reviews.
I would appreciate your comments. Additionally I may, a bit later on, do some tiling for walls and floor.From my on line reading it appears a non segmented disc would be preferable to the segmented disc I referred to earlier for paving.
I have seen these advertised for £3.41 each (#868730) also supported by many good reviews.
Thank you.
Thank you.
Spiderman
- Has thanked: 1415 times
- Been thanked: 4027 times
Re: Which Diamond Cutting Discs?
My advice would be....
Avoid Silverline like the plague...
- Job and Knock
- Old School Chippie
- Has thanked: 742 times
- Been thanked: 1573 times
Post by Job and Knock »
You do indeed get what you pay for, so I'm another naysayer when it comes to Silverline! To date the diamond discs I've bought myself have been either Spectrum or Makita, so far only for mortar raking, although the brickies on one job last year were issued with Bosch discs which they didn't complain about. Quick search on eBay turned up these at £6.99 which should be reasonable as well as affordable. If you want to frighten yourself with the prices on pro discs, then take a look here. In the past the main problems I've had with cheap discs were that they were poorly balanced; this results in a lot of extra noise and vibration, neither of which I welcome! My own "work" angle grinder is a Metabo W8-115, so I'm using the same size as yourself, albeit mainly for metal cutting in rip-outs (before we start putting-in the joinery)
Job and Knock
- Inky Pete
- Has thanked: 12 times
- Been thanked: 161 times
I've always struggled to get all the way through full thickness paving slabs with a 4 1/2" grinder - so out comes the trusty but scary 9" beast.
Mind you, all my paving is 50mm thick 900mm x 600mm concrete monoliths. For thinner stuff the 4 1/2" will be fine.
Inky Pete
Thank you guys for your sound advice and a special thanks to wine~o for the warm welcome.
Apologies for not replyng sooner. I was out early all day Friday and returned late in the evening.
I am clear now, from your replies, on the brand of disc I will probably settle for. It looks lke Bosch are a good value for money bet.
I do, however, have one more query.
It s my understanding, rightly or wrongly, that segmented diamond discs cause a lot of dust, noise and not as clean a cut as a non segmented dicsc.
Would it, therefore, be better rather to start with a non segmented disc or is there no real significance between them?
Many thanks.
Many thanks.
Spiderman
- ayjay
- Has thanked: 458 times
- Been thanked: 1708 times
They will both create plenty of dust.Spiderman wrote:
It s my understanding, rightly or wrongly, that segmented diamond discs cause a lot of dust, noise and not as clean a cut as a non segmented disc.
Many thanks.
Segmented blades will produce a clean enough cut for paving - to some extent it's down to how you use it.
Some non-segmented blades have to be used wet - so be careful which you buy, (or how you use it).
ayjay
- Inky Pete
Lots and lots of dust!!!!
Goggles, mask and ear defenders definitely required.
Inky Pete
Thanks Ay Jay. Most helpful. Thanks also to you Inky Pete for your continued appreciated comments in taking the time to reply.
That about wraps it up for now. A segmented Diamond cutting Bosch disc it is going to be.
I must say I am very impressed with the forum and the quality of the replies including the practical nature contained in them. Well done everyone.
Many thanks indeed to all who responded to my questions.
Spiderman
