I have a very old bench grinder (so old it was made in Australia) and a brand new linishing belt I was hoping to attach to it. The problem is I can't get the old shield off because I can't get the "spindle" off (arrowed in the photograph attached). I managed to get my 2 leg puller under it, but it didn't budge. I imagine the whole thing can't slip-off otherwise the grinding wheel might just do the same.
Ian
Anyone have any ideas?- Ultimate Handyman Forum Index DIY Forum/Home improvement Metalworking Forum
- It is currently Mon Mar 10, 2025 5:35 am
trouble getting a bench grinder apart
steerage250
- BillyGoat
- Troll Headbutter
- Has thanked: 386 times
- Been thanked: 796 times
Re: trouble getting a bench grinder apart
It's not welded to the guard is it? Remove the three screws and it'll pull off....or does it spin with the shaft?
BG
BG
BillyGoat
- Has thanked: 739 times
- Been thanked: 2350 times
you cant take it off as you need it to tighten the wheel to
if you remove it how would you secure anything to the shaft??
- EJJ150847
- Has thanked: 35 times
- Been thanked: 188 times
Is it a left handed thread?
What handed thread is the nut that holds the wheel on?
John
John
EJJ150847
- Has thanked: 7 times
- Been thanked: 37 times
Start with penetrating oil then two wedges behind it, put the nut back on until its almost flush with the thread, tap the nut then the wedges. also the puller and wedges at the same time, if you use heat, only heat the washer and not the shaft. its just presed on.
merlin50
- Has thanked: 77 times
- Been thanked: 335 times
That should just be a nice push fit on there usually, occasionally need tapping over.
They do become pretty tight with use though.
Its not fixed to the shaft or guard permanently, else it would be impossible to take apart or assemble when new
The easiest way to loosen, is just to tap the edge of it turn it, tap it, turn it, tap it...it should show signs of loosening, then try your puller.
. it may well have a couple of flats that sit on a shoulder on the shaft, similar to an angle grinder.
Hitch
