laptops got a knackered battery
- Has thanked: 32 times
- Been thanked: 806 times
ok i have a acer aspire 5332 laptop. if i turn it on wihtout the charger plugged in it will work for a few minutes then turn off. it says theres a fault with the battery. so new battery needed.
its an as09a31 battery apparently. 10.8v 4400 mah 48wh
so whats the craik with buying genuine acer, or a different make equivalent with a higher capacity?
anyone recomend any websites to buy from? ive checked ebay out but dunno where else to go.
what about the ones that ship from china? to be avoided? my current original battery states its cells are made in japan but its assembled in china.
- kellys_eye
- Has thanked: 357 times
- Been thanked: 1790 times
Re: laptops got a knackered battery
There are UK suppliers of battery packs that even offer guarantees! I got a replacement pack for my Acer 5735Z which has dropped from 2.2 hours life (when first fitted some 9 months ago) to 1.5 hours. But, to be fair, I leave the thing plugged in and powered by the adapter ALL the time so it won't be doing the battery any good as far as lifespan is concerned!
You have to 'work' a battery to maintain its reliability.
My new pack is 'slightly' higher capacity than the original but I don't use it off-line on many (any?) occasions anyway so unless you do wouldn't bother getting a larger pack.
I'd give you the link to the eBay site I got my battery from except I've closed that account since then so can't access it - bugger.
Anyway I suspect it was someone like this:
http://www.ebay.co.uk/itm/For-Acer-Aspi ... 27cd2becf1
this is the original battery. got a few years out of it like.
so is there much difference between an acer battery and a copy battery?
£30 ish for a genuine battery or a shade more than a tenner...
also.. what can i do with the broke battery? cant just hoy em in the bin these days. can i drop em off at the tip or anything to be recycled?
- kellys_eye
Stuff the rules - hoy it in the bin.
Potentially there is no difference between OEM and 'copy' batteries - this assumes that the copy battery maker uses full-spec cells in their battery packs - something I wouldn't bet the house on.
Either way, if you plan to use it as a proper lappy (i.e. off the mains for most of its life) then get an original replacement. If you only go portable once or twice a week then I'd buy TWO cheap ones and carry the spare as well.
jus use it for goin online and that. it annoys me to have it plugged in. but the charger is here incase. except now it lasts about 10 minutes before its flat
ok i guess i could just try a copy battery for now.
haha ill check the tip out. if theres a space for broke pc's n that there must be somewhere to put batteries
![angry :angryfire:](./images/smilies/angryfire.gif)
- ayjay
- Has thanked: 458 times
- Been thanked: 1708 times
I'm guessing you don't do much food shopping: but most of the supermarkets around here have various re-cycling bins including one for batteries.fin wrote:
- steviejoiner74
- Has thanked: 747 times
- Been thanked: 1616 times
When my laptops battery gave up the ghost I ended up just getting an ipad,loads better for my needs now and no need to have it plugged in either.
canny idea like. i have a kindle fire. but ive only used it for books n the like.steviejoiner74 wrote:When my laptops battery gave up the ghost I ended up just getting an ipad,loads better for my needs now and no need to have it plugged in either.
ive got an iphone so already use apple stuff.
- steviejoiner74
That's what swayed it for me,got an iPhone and loved it and my misses got me an iPad Air for my 40th.
Everything just synched together,photos and all the apps.
I just use it for fun,Facebook and web browsing so it suits me.
My phone contracts up in about 6 months and I'm gonna get the iPhone 6 for sure!!
yep ive kept my 4s since its contract ended. i went to 3 mobile on a rolling monthly deal. new that if i got a 5s or whatever id be gutted come the release of the 6.
itll be upon us soon enough.
- peter c
- Has thanked: 6 times
- Been thanked: 16 times
Fin I have bought a battery for Mrs C's Acer laptop some while ago. I got it from www.laptopsandspares.com (no connection) just recommended by my brother. Very good service and reasonable price.
HTH
Peter C
HTH
Peter C
The end justifies the means
