Stud Wall
Stud Wall
Feel a bit of muppet asking as I don't feel completely useless when it comes to diy : I am building a stud wall over Xmas which is only just over 2 metres long and incorporates a door frame. I was going to use 3x2 and assumed that the 3 inches was the depth of the wall, but once I add the plasterboard to it the wall will then be 4 inches thick, an inch too thick for my 3 inch door frame ( the plasterboard will overlap the door frame rather than butt up to it ). Am I being a pratt? Or, is it the 2 inches that is the depth?
Please be gentle with me lol
Gerry.
Gerry.
Hi Gerry,
welcome to the forum
Don't be silly, It's just that you don't know and at least have the sense to ask first. Many people ask afterwards when it is too late!
You will need a deeper door case, a minimum of 4 inches deep or you can nail a piece of timber to the existing one to make it deeper. There is a name for this piece of wood, but it escapes me at the minute
Best wait and see what the pro's say. You might be able to use the 3*2 the other way around, but I'm not sure and so please wait for someone that knowsMUNGO64 wrote:Thanks for your quick reply. I only asked because I am building the new door frame into the stud wall and all my other doors are 3 inches thick. For such a short wall can I use 2x2 instead? Or, will this not be strong enough.
Thanks again.
- Wood Magnet
- Been thanked: 3 times
- dirtydeeds
- Craftsman Carpenter
- BANNED
Morning Boys and Girls
If you don’t mind me asking MUNGO64 but did you purchase or come across a door lining first and decided to make the wall to fit the door lining or is the space a problem?
Anyway up as they say consider using a system which in days of old went by the name of Paramount Plasterboard partition walling and was made by British Gypsum, I have had a very quick look on there site but could not find any thing.
So I went on Lafarge website and I won a cocoanut, there system goes by the name of panelplus. http://www.lafargeplasterboard.co.uk/si ... search.asp
http://www.lafargeplasterboard.co.uk/se ... l_plus.pdf
You will see you can have non-loadbearing walls with an overall thickness of 57 or 63mm.
Check it out and it may just be the answer to your dilemma.
You can have a look at the British Gypsum site by using this link British Gypsum http://www.british-gypsum.bpb.com/liter ... _book.aspx
